#3805: Export vector map (table with column name, which is reserved PostgreSQL
keyword) into the PostGIS database
Reporter: tmsz | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.6.2
Component: Database | Version: svn-releasebranch76
Keywords: v.out.postgis | CPU: All
Platform: All |
I work with openstreemap vector line map "planet_osm_line" imported from
PostGIS database into the GRASS GIS. If I want export (via v.out.postgis)
this vector map back into the PostGIS database I got error message
(because one of the table column name is "NATURAL", which is reserved
PostgreSQL database keyword, according https://www.postgresql.org/docs/current/sql-keywords-appendix.html)
I write patch which enclose column name in double-quotes in the sql
command during export.
Type: defect | Status: closed
Resolution: fixed | Keywords: v.out.postgis
CPU: All | Platform: All
Changes (by neteler):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"74386" 74386]:
#!CommitTicketReference repository="" revision="74386"
libvector: support reserved PostgreSQL keywords as column name by quoting
when exporting vector map to PostGIS database (contributed by tmsz; fixes #3805)
