#3806: db.copy: fails with pg as to_driver
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.8.0
Component: Database | Version: unspecified
Keywords: db.copy | CPU: Unspecified
Platform: Linux |
db.copy fails to open a pg connection.
Tried syntax from the example as well as syntax as used in v.out.ogr.
Might make sense to unify the way DB connection strings are handled in
different modules... As the pg driver usage in db.copyis inconsistent with
e.g. v.in.ogr or v.out.ogr.
Resolution: | Keywords: db.copy
CPU: Unspecified | Platform: Linux
Comment (by mmetz):
Replying to [ticket:3806 sbl]:
The pg connection needs to be registered first with db.login
v.[in|out].ogr use the OGR syntax which is different from the GRASS
syntax. In GRASS, you only need to specify the driver and the database
name, whereas in OGR you need to use a syntax like
"PG:"dbname='databasename' host='addr' port='5432' user='x' password='y'"
Comment (by sbl):
Thanks for the info. Will try and update the manual accordingly as it
currently lacks info about the required db.login step...
It might be still worth considering to unify module syntax (e.g. using
whitespace instead of comma for separating elements of the connection
string) as well as using .pgpass file... Even if it is just minor
cosmetics, it would help making things a bit more intuitive...
