[GRASS-dev] [GRASS GIS] #3810: r.external.out: format parameter wish
Reporter: neteler | Owner: grass-dev@…
Priority: normal | Milestone: 7.8.0
Component: Raster | Version: svn-trunk
Keywords: r.external.out, GDAL | CPU: Unspecified
Platform: Unspecified |
So far r.external.out does not allow to enforce the output format as
r.out.gdal does. A new parameter would be nice to have for this.
Rationale: writing out NDVI * 1000 as Int16 is currently not possible with
r.external.out as NBITS=16 isn't properly accepted (GDAL refuses to accept
it as currently Int32 is written out).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3810&gt;
      Type: enhancement | Status: closed
Resolution: invalid | Keywords: r.external.out, GDAL
Changes (by mmetz):
* status: new => closed
* resolution: => invalid
Comment:
Replying to [ticket:3810 neteler]:
with r.external.out as NBITS=16 isn't properly accepted (GDAL refuses to
accept it as currently Int32 is written out).
This is not concerning the format, but the datatype. The name of the
module is
r.external.out - Redirects raster output to file utilizing GDAL library
rather than storing in GRASS raster format.
That means all raster output is written in the selected GDAL format.
Obviously the datatype can vary, depending on which raster output is
created.
In this example, writing out as Int16 is only possible if all cell values
fit into Int16. But all cell values are not known when writing out, i.e.
you need to write out the raster in GRASS native format and then determine
which GDAL datatype is suitable to store the GRASS raster map. In this
case you need to use r.out.gdal.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3810#comment:1&gt;
