[GRASS-dev] [GRASS GIS] #3814: v.buffer: sefault in LL
Reporter: neteler | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.8.0
Component: LibVector | Version: svn-trunk
Keywords: v.buffer | CPU: Unspecified
Platform: Unspecified |
Inspired by an article [1] I tried v.buffer in a EPSG 4326 location:
GRASS 7.7.svn (latlong_wgs84):~ >
g.region n=90 s=-90 w=-180 e=180 res=1
v.random output=random100 n=100
v.buffer input=random100 output=random100_buff distance=0:00:01
Note: In latitude-longitude coordinate system specify distances in degree
unit
Buffering features...
Segmentation fault (core dumped)
Minimal debugging:
gdb v.buffer
GNU gdb (GDB) Fedora 8.2-6.fc29
(gdb) r input=random100 output=random100_buff distance=0:00:01 --o
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff7f71bc4 in Vect_point_buffer2 () from
/home/mneteler/software/grass77/dist.x86_64-pc-linux-
gnu/lib/libgrass_vector.7.7.so
Version:
g.version -g
version=7.7.svn
date=2019
revision=r74334M
build_date=2019-04-02
build_platform=x86_64-pc-linux-gnu
build_off_t_size=8
In G76 it also crashes.
[1] https://spatialthoughts.com/2019/04/05/geodesic-buffers-in-qgis/
Ticket URL: <https://trac.osgeo.org/grass/ticket/3814&gt;
#3814: v.buffer: segfault in LL
Resolution: | Keywords: v.buffer
Ticket URL: <https://trac.osgeo.org/grass/ticket/3814#comment:1&gt;
Comment (by mmetz):
Replying to [ticket:3814 neteler]:
degree
> unit
`distance=0:00:01` becomes `distance=0` because distance must be of type
double, in this case 1/3600 = 0.0002777778
Ticket URL: <https://trac.osgeo.org/grass/ticket/3814#comment:2&gt;
Comment (by mmetz):
In [changeset:"74387" 74387]:
#!CommitTicketReference repository="" revision="74387"
v.buffer: +test for zero distance, see #3814
Ticket URL: <https://trac.osgeo.org/grass/ticket/3814#comment:3&gt;
Comment (by mmetz):
In [changeset:"74388" 74388]:
#!CommitTicketReference repository="" revision="74388"
v.buffer: +test for zero distance, see #3814 (backport trunk r74387)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3814#comment:4&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.buffer
Changes (by neteler):
* status: new => closed
* resolution: => fixed
Comment:
Thanks, fixed!
Yes, the zero distance results from me having specified the distance in
sexagesimal notation.
g.region uses G_scan_northing() etc for that. But that's probably for a
separate enhancement ticket.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3814#comment:5&gt;
