[GRASS-dev] [GRASS GIS] #3815: compression: libzstd should be a default config and a requirement if ZSTD is default compression method
Reporter: mlennert | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.8.0
Component: Raster | Version: svn-trunk
Keywords: compression zstd zlib | CPU: Unspecified
Platform: Unspecified |
I just came upon the problem that in my grass installation ZSTD is
configured and I thus worked with raster data which was automatically
compressed using ZSTD, but when I transferred the data to our HPC system,
I realized that grass there is not configure with ZSTD and the latter is
currently not available on the system.
As the r.compress man page says, ZSTD is the default compressor if
available. However, when I check in current trunk's configure, it says:
   --with-zstd support Zstandard functionality (default: no)"
Does that mean that even if libzstd is available on a system, GRASS is not
compiled with support for it, unless --with-zstd is set ?
I find this situation a bit uncomfortable as it can lead to situations
where the user creates data without actively thinking about the
compression method and this data is the unusable elsewhere.
I would plead, thus, for libzstd to become a compulsory requirement for
GRASS GIS, and for the configure script to default to --with-zstd=yes.
Or the default compression method should be put back to ZLIB.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815&gt;
Resolution: | Keywords: compression zstd zlib
Comment (by mmetz):
Replying to [ticket:3815 mlennert]:
not compiled with support for it, unless --with-zstd is set ?
yes
Done in trunk r74391. The default is now `--with-zstd=yes`, you can
disable ZSTD support with `--with-zstd=no`. To be backported I guess.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815#comment:1&gt;
Comment (by mlennert):
Replying to [comment:1 mmetz]:
no)"
> yes
for GRASS GIS, and for the configure script to default to --with-zstd=yes.
+1 for backporting.
Should libzstd be added to REQUIREMENTS.html ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815#comment:2&gt;
Comment (by mmetz):
Replying to [comment:2 mlennert]:
> > > I would plead [...] for libzstd to become a compulsory requirement
> +1 for backporting.
Done in relbr76 r74398
Yes, done in r74396,9 (trunk, relbr76)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815#comment:3&gt;
  Priority: normal | Milestone: 7.6.2
Changes (by martinl):
* milestone: 7.8.0 => 7.6.2
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815#comment:4&gt;
Comment (by neteler):
Replying to [comment:3 mmetz]:
> > +1 for backporting.
Just FYI:
This broke the manual-building cronjobs on the grass.osgeo.org server but
I fixed it by now actively disabling zstd in the configure step (Debian
Jessie doesn't have zstd yet and #3486 = compile in a docker container is
still open).
In any case, the manuals on the server are now back.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815#comment:5&gt;
Comment (by mmetz):
Replying to [comment:5 neteler]:
> > > +1 for backporting.
> Just FYI:
but I fixed it by now actively disabling zstd in the configure step
(Debian Jessie doesn't have zstd yet and #3486 = compile in a docker
container is still open).
A good reason to not make zstd a compulsory requirement. Debian Jessie has
long-term support until 30 June 2020, and GRASS 7.x should IMHO run on
this system (with appropriate configure options).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815#comment:6&gt;
Comment (by mmetz):
Replying to [comment:6 mmetz]:
> > > > +1 for backporting.
> > Just FYI:
has long-term support until 30 June 2020, and GRASS 7.x should IMHO run on
I think there was some misunderstanding from my side. For maximum
compatibility of GRASS raster data, the default compression should indeed
be ZLIB, even if ZSTD is available. I made ZSTD the default if available
in order to get it tested.
There was one issue reported where raster data compressed with ZSTD 1.3.6
could not be read with ZSTD 1.3.1, which remains a mystery.
What are the opinions on changing the default compression back to ZLIB
even if ZSTD is available?
+1 from Moritz Lennert as I understand
0 from me
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815#comment:7&gt;
Comment (by martinl):
Replying to [comment:7 mmetz]:
> 0 from me
+1
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815#comment:8&gt;
> > > > > +1 for backporting.
> > > Just FYI:
server but I fixed it by now actively disabling zstd in the configure step
1.3.6 could not be read with ZSTD 1.3.1, which remains a mystery.
Yes.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815#comment:9&gt;
Comment (by mmetz):
In [changeset:"74426" 74426]:
#!CommitTicketReference repository="" revision="74426"
libgis: make ZLIB the default compressor even if ZSTD is available, see
#3815
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815#comment:10&gt;
Comment (by mmetz):
Replying to [comment:10 mmetz]:
#3815
This change means that newly created raster maps are by default compressed
with ZLIB, unless the environment variable GRASS_COMPRESSOR is set.
Previously created raster maps compressed with ZSTD are readable as long
as GRASS 7.6 is compiled with ZSTD.
Trunk still uses ZSTD as default if available.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815#comment:11&gt;
Please note that this change in 7.6 contradicts our release announcement:
https://trac.osgeo.org/grass/wiki/Release/7.6.0-News#Librarychanges
"libraster: ZSTD is now the default compression if available"
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815#comment:12&gt;
Comment (by mmetz):
Replying to [comment:12 neteler]:
announcement:
The release announcement for 7.6.2 should then include something like
The default compression has been changed back to ZLIB, even if ZSTD
compression is available, because not all currently supported systems
provide ZSTD with standard package management tools, and because problems
were encountered regarding compatibility with different ZSTD 1.3.x
versions.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815#comment:13&gt;
Replying to [comment:13 mmetz]:
announcement:
versions.
Added in new draft: https://trac.osgeo.org/grass/wiki/Release/7.6.2-News
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815#comment:14&gt;
As a reference, the related relbranch76 change in GH:
https://github.com/OSGeo/grass/commit/d3e60da04e0e5f7be151ee3a51deb8c6135e0527
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815#comment:15&gt;
For the record: in G7.8 and master ZSTD is the default compression:
https://github.com/OSGeo/grass/blob/releasebranch_7_8/lib/gis/compress.c#L126
* https://github.com/OSGeo/grass/blob/master/lib/gis/compress.c#L126
As we didn't get any complaints with that, I suggest to keep it as is.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815#comment:16&gt;
Comment (by wenzeslaus):
Problems reported between Oct 31, 2019 and now:
* [https://lists.osgeo.org/pipermail/grass-dev/2019-December/093800.html
ZSTD error]
* [https://lists.osgeo.org/pipermail/grass-dev/2020-May/094351.html ZSTD
compression error on Windows]
Generally speaking, changing the default in minor version became challenge
for users sharing data (locations, packs) with other users
([https://lists.osgeo.org/pipermail/grass-dev/2019-December/093802.html
...choice of raster compression method...]) since the requirement was
version 7.6 compiled //with newly introduced ZSTD//. Expected issues
between major versions, but not minor ones.
Even more problems were created by compatibility issues between different
ZSTD versions.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815#comment:17&gt;
Comment (by annakrat):
Another reported problem:
https://gis.stackexchange.com/questions/368823/r-grow-distance-with-r
-mask-returns-errors-on-a-global-scale-but-not-with-a-sma
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815#comment:18&gt;
Replying to [comment:18 annakrat]:
Yes, but reported with GRASS GIS 7.6 and ZSTD 1.3.2.0.
Currently ZSTD 1.4.4-1 is shipped in OSGeo4W).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815#comment:19&gt;
