[GRASS-dev] [GRASS GIS] #382: r.texture NULL or negative value ERROR (possible r.null problem)
Reporter: khufkens | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: minor | Milestone: 6.3.1
Component: Raster | Version: 6.3.0
Keywords: r.texture r.null ERROR null negative values | Platform: Linux
      Cpu: Unspecified |
Concerning r.texture in GRASS 6.3:
Running r.texture on a map after r.null (should have) replaced all NULL
values still produces an error indicating a persistent NULL or negative
value in the map.
r.category shows no NULL values or negative values but yet they are there
for r.texture...
Adding a fixed value to the map with the map calculator or running a
running window analysis removes these hidden values and also removes the
error.
This traces back to either an error in r.texture or r.null, not sure...
Ticket URL: <http://trac.osgeo.org/grass/ticket/382&gt;
Resolution: | Keywords: r.texture r.null ERROR null negative values
  Platform: Linux | Cpu: Unspecified
Comment (by neteler):
for the record:
On Tue, Nov 25, 2008 at 2:29 AM, Hamish:
> maybe something like this:
http://trac.osgeo.org/grass/changeset?new=grass%2Ftrunk%2Fraster%2Fr.los%2Fpts_elim.c%4025104&old=grass%2Ftrunk%2Fraster%2Fr.los%2Fpts_elim.c%4018934
Ticket URL: <http://trac.osgeo.org/grass/ticket/382#comment:1&gt;
Comment (by hamish):
what does r.univar say, before and after r.null?
(run 'g.region rast=yourmap' first)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/382#comment:2&gt;
      Type: defect | Status: closed
Resolution: worksforme | Keywords: r.texture r.null ERROR null negative values
Changes (by khufkens):
  * status: new => closed
  * resolution: => worksforme
Comment:
Ok,
seems that setting g.region makes the error disappear. Sorry, for the
inconvencience...
Koen
Ticket URL: <https://trac.osgeo.org/grass/ticket/382#comment:3&gt;
