[GRASS-dev] [GRASS GIS] #3829: pygrass.gis.Region.from_rast + mapset parameter
Reporter: pmav99 | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: PyGRASS | Version: svn-trunk
Keywords: | CPU: Unspecified
Platform: Unspecified |
{{{pygrass.gis.Region.from_rast}}}'s docstring mentions {{{mapset}}} as a
function parameter but it is missing from the function's signature. It
should either be added or removed from the docs.
If it is added, it should also be added to {{{Region.from_vect()}}}.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3829&gt;
Resolution: | Keywords:
Comment (by neteler):
I see "mapset=" present in pygrass/raster/abstract.py
`set_region_from_rast()`.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3829#comment:1&gt;
