#3831: d.grid: -g and -w flags do not display any grid
Reporter: veroandreo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.6.2
Component: Display | Version: svn-releasebranch76
Keywords: d.grid | CPU: Unspecified
Platform: Linux |
I have tested in NC location and in an UTM location with no success.
Resolution: | Keywords: d.grid
CPU: Unspecified | Platform: Linux
Comment (by Nikos Alexandris):
Here, works using the PNG driver or the wxGUI. Unfortunately, in my setup,
I cannot test a 'wx' monitor! But, isn't 'wx' essentially the same as the
GUI?
Type: defect | Status: closed
Resolution: invalid | Keywords: d.grid
Changes (by veroandreo):
* status: new => closed
* resolution: => invalid
Comment:
Indeed! And it also works as expected in wx monitors. Thanks for the heads
up
If -g or -w is to be used in a projected location (no need to use them if
location is latlon), size must be in degrees and not really in map units
(m or other).
Closing as invalid (should have read the manual more carefully)
