[GRASS-dev] [GRASS GIS] #3834: Add .save() method to pygrass.gis.region.Region
Reporter: pmav99 | Owner: grass-dev@…
Priority: normal | Milestone:
Component: PyGRASS | Version: svn-trunk
Keywords: | CPU: Unspecified
Platform: Unspecified |
The {{{Region()}}} objects are missing a method for saving the Region
settings to a Region file.
As a result, it is not really possible to use {{{WIND_OVERRIDE}}} with
{{{Region}}} objects without resorting to use `g.region`. The following
snippet is a possible implementation of a {{{save()}}} method:
     def save(self, filename):
         Save the Region settings to the specified Region file.
         This is the equivalent of `g.region save=filename --overwrite`
         The region file will be created inside the `$MAPSET/windows`
directory.
         if not grass.legal_name(filename):
             raise ValueError("Illegal filename: %s", filename)
         self.adjust()
         ret = libgis.G_put_element_window(self.byref(), "windows",
filename)
         if ret < 0:
             raise ValueError("Couldn't save the region settings at: %s",
filename)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3834&gt;
  Priority: normal | Milestone: 7.8.0
Resolution: | Keywords:
Changes (by martinl):
* milestone: => 7.8.0
Ticket URL: <https://trac.osgeo.org/grass/ticket/3834#comment:1&gt;
Comment (by neteler):
Should this go into lib/python/pygrass/gis/region.py ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3834#comment:2&gt;
