#3836: GRASS: db.in.ogr fails where v.in.ogr succeeds
Reporter: Lads | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Vector | Version: unspecified
Keywords: | CPU: x86-64
Platform: Linux |
This report refers to GRASS 7.6. To import a spatial table from PostGIS I
use, successfully, the following formulation with v.in.ogr:
> v.in.ogr input="PG:host=pg-server dbname=dsm user=duque004
password=secret" layer="observations.profiles" output=profiles -o
Over-riding projection check
Check if OGR layer <observations.profiles> contains polygons...
ERROR 1: Could not fetch SRS:
100%
Creating attribute table for layer <observations.profiles>...
Importing 141584 features (OGR layer <observations.profiles>)...
100%
Building topology for vector map <profiles@test>...
Registering primitives...
But if I feed the same parameters to db.in.ogr, it fails to find the
table:
> db.in.ogr input="PG:host=pg-server dbname=dsm user=duque004
password=secret" db_table="observations.profiles" output=profiles
ERROR: Unable to open data source <observations.profiles>
ERROR: Input table <observations.profiles> not found or not
readable
This bug report is related to the following discussions at StackExchange:
[https://gis.stackexchange.com/q/316383/21532\]
[https://gis.stackexchange.com/q/316100/21532\]
Ticket URL: <https://trac.osgeo.org/grass/ticket/3836>
