[GRASS-dev] [GRASS GIS] #3837: OSGeo4W winGRASS77svn - startup error: TypeError: endswith first arg must be bytes or a tuple of bytes, not str
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Priority: blocker | Milestone: 7.8.0
Component: Python | Version: svn-trunk
Keywords: python3, py3, wingrass | CPU: Unspecified
Platform: MSWindows |
taken from [https://lists.osgeo.org/pipermail/grass-
dev/2019-April/092079.html dev ML 1]
just tried to start the latest OSGeo4W winGRASS77svn daily build:
C:\>grass77svn
Starting GRASS GIS...
   File "C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\gis_set.py", line 34,
in
<module>
     from core import globalvar
   File "C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\core\globalvar.py",
line
35, in <module>
     from core.debug import Debug
   File "C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\core\debug.py", line
77,
in <module>
     Debug = DebugMsg()
39,
in __init__
     self.SetLevel()
45,
in SetLevel
     self.debuglevel = int(grass.gisenv().get('WX_DEBUG', 0))
   File "C:\OSGEO4~1\apps\grass\grass77\etc\python\grass\script\core.py",
line 1074, in gisenv
     s = read_command("g.gisenv", flags='n', env=env)
line 494, in read_command
     process = pipe_command(*args, **kwargs)
line 463, in pipe_command
     return start_command(*args, **kwargs)
line 393, in start_command
     return Popen(args, **popts)
line 54, in __init__
     cmd = shutil_which(args[0])
   File "C:\OSGEO4~1\apps\Python37\lib\shutil.py", line 1151, in which
     if any(cmd.lower().endswith(ext.lower()) for ext in pathext):
   File "C:\OSGEO4~1\apps\Python37\lib\shutil.py", line 1151, in <genexpr>
ERROR: Error in GUI startup. See messages above (if any) and if necessary,
please report this error to the GRASS developers.
On systems with package manager, make sure you have the right GUI package,
probably named grass-gui, installed.
To run GRASS GIS in text mode use the --text flag.
Use '--help' for further options
      grass77 --help
See also: https://grass.osgeo.org/grass77/manuals/helptext.html
Exiting...
Drücken Sie eine beliebige Taste . . .
anyone any idea?
additional info [https://lists.osgeo.org/pipermail/grass-
dev/2019-April/092080.html dev ML 2]
C:\>g.version -g
version=7.7.svn
date=2019
revision=r74428M
build_date=2019-04-26
build_platform=x86_64-w64-mingw32
build_off_t_size=8
and [https://lists.osgeo.org/pipermail/grass-dev/2019-April/092081.html
dev ML 3]
Same error on Vista with same version. Locale is set to Latvia.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3837&gt;
Resolution: | Keywords: python3, py3, wingrass
       CPU: Unspecified | Platform: MSWindows
Comment (by hellik):
Replying to [ticket:3837 hellik]:
> Hi,
> C:\>grass77svn
34, in
> <module>
line
> 35, in <module>
77,
> in <module>
> Debug = DebugMsg()
39,
> in __init__
> self.SetLevel()
45,
> in SetLevel
<genexpr>
necessary,
package,
> grass77 --help
> Exiting...
> anyone any idea?
> C:\>g.version -g
> version=7.7.svn
> date=2019
> revision=r74428M
> build_off_t_size=8
dev ML 3]
see also
https://trac.osgeo.org/grass/ticket/3733
Ticket URL: <https://trac.osgeo.org/grass/ticket/3837#comment:1&gt;
Replying to [comment:1 hellik]:
> see also
and also see
https://trac.osgeo.org/grass/ticket/3723
Ticket URL: <https://trac.osgeo.org/grass/ticket/3837#comment:2&gt;
Replying to [comment:2 hellik]:
> > see also
> and also see
it seems there is still some encoding/decoding issue
Ticket URL: <https://trac.osgeo.org/grass/ticket/3837#comment:3&gt;
Replying to [comment:3 hellik]:
> > > see also
> > and also see
it's around
195 if sys.platform == "win32":
196 # The current directory takes precedence on Windows.
197 if not os.curdir in path:
198 path.insert(0, os.curdir)
199
200 # PATHEXT is necessary to check on Windows (force
lowercase)
201 pathext = list(map(lambda x: encode(x.lower()),
202 os.environ.get("PATHEXT",
"").split(os.pathsep)))
203 if b'.py' not in pathext:
204 # we assume that PATHEXT contains always '.py'
205 pathext.insert(0, b'.py')
206 # See if the given file matches any of the expected path
extensions.
207 # This will allow us to short circuit when given
"python.exe".
208 # If it does match, only test that one, otherwise we have
to try
209 # others.
210 if any(cmd.lower().endswith(ext) for ext in pathext):
211 files = [cmd]
212 else:
213 files = [cmd + ext for ext in pathext]
Ticket URL: <https://trac.osgeo.org/grass/ticket/3837#comment:4&gt;
Comment (by pmav99):
The traceback in the original post indicates that the problematic line is:
which currently has been changed to (I guess with other changes, too):
Could you please paste an updated traceback?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3837#comment:5&gt;
Replying to [comment:5 pmav99]:
is:
https://trac.osgeo.org/grass/browser/grass/trunk/lib/python/script/core.py#L210
199
lowercase)
extensions.
"python.exe".
to try
209 # others.
211 files = [cmd]
212 else:
C:\>g.version -breg
version=7.7.svn
date=2019
revision=r74474M
build_date=2019-05-08
build_off_t_size=8
  ./configure --host=x86_64-w64-mingw32 '--with-
libs=/c/msys64/usr/src/grass_trunk/mswindows/osgeo4w/lib ' --with-
includes=/c/OSGeo4W64/include --libexecdir=/c/OSGeo4W64/bin
--prefix=/c/OSGeo4W64/apps/grass --bindir=/c/OSGeo4W64/bin
--includedir=/c/OSGeo4W64/include --without-x --with-cxx --enable-shared
--enable-largefile --with-fftw --with-freetype --with-proj-
share=/c/OSGeo4W64/share/proj --with-
gdal=/c/msys64/usr/src/grass_trunk/mswindows/osgeo4w/gdal-config --with-
geos=/c/msys64/usr/src/grass_trunk/mswindows/osgeo4w/geos-config --with-
sqlite --with-regex --with-nls --with-freetype-
includes=/c/OSGeo4W64/include/freetype2 --with-zstd --with-odbc --with-
cairo --with-postgres --with-opengl=windows --with-bzlib --with-
liblas=/c/msys64/usr/src/grass_trunk/mswindows/osgeo4w/liblas-config
libgis_revision=74118
libgis_date="2019-02-21 10:38:28 +0100 (Thu, 21 Feb 2019) "
proj4=5.2.0
gdal=2.4.1
geos=3.7.0
sqlite=3.26.0
with r74474
C:\>g.gui wxpython
Launching <wxpython> GUI in the background, please wait...
   File "C:\OSGEO4~1\apps\grass\grass77/gui/wxpython/wxgui.py", line 32, in
<module>
line 35, in <module>
77, in <module>
     Debug = DebugMsg()
39, in __init__
     self.SetLevel()
45, in SetLevel
line 1075, in gisenv
line 495, in read_command
line 464, in pipe_command
line 394, in start_command
Ticket URL: <https://trac.osgeo.org/grass/ticket/3837#comment:6&gt;
Replying to [comment:6 hellik]
> with r74474
> C:\>g.gui wxpython
in <module>
77, in <module>
> Debug = DebugMsg()
39, in __init__
> self.SetLevel()
45, in SetLevel
<genexpr>
starting the GUI
in <module>
77, in <module>
     Debug = DebugMsg()
39, in __init__
     self.SetLevel()
45, in SetLevel
      grass77 --help
Exiting...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3837#comment:7&gt;
is:
looking into
C:\OSGeo4W64\apps\grass\grass77\etc\python\grass\script\core.py
             files = [cmd]
         else:
the question is why the traceback reports then:
Ticket URL: <https://trac.osgeo.org/grass/ticket/3837#comment:8&gt;
I am not sure I understand the last question. If you are asking why the
same line is being repeated, then, quoting from
[https://nedbatchelder.com/blog/201812/a_thing_i_learned_about_python_recursion.html
here]:
> In Python 3, all comprehensions (and in Python 2 all except list
comprehensions) are actually compiled as nested functions. Executing the
generator comprehension calls that hidden nested function, using up an
extra stack frame.
Generator functions are treated the same way. You can easily check this
like this:
$ python -c 'list(1 / i for i in (1, 2, 3, 0, 4, 5))'
   File "<string>", line 1, in <module>
   File "<string>", line 1, in <genexpr>
ZeroDivisionError: division by zero
Ticket URL: <https://trac.osgeo.org/grass/ticket/3837#comment:9&gt;
Now to the problem at hand.
Pathext is an iterable (in this case a list) and the problem seems to be
that at least one of the pathext elements is a string instead of a bytes
object. Now, I don't understand why this happens, since lines 200-201
should handle the conversion to bytes. Anyway, to debug this try to add
the following line just before the problematic one:
import pprint
pprint.pprint([ext, type(ext) for ext in pathext])
Ticket URL: <https://trac.osgeo.org/grass/ticket/3837#comment:10&gt;
Replying to [comment:9 pmav99]:
here]:
it's not the repeated Line, but in the script
''if any(cmd.lower().endswith(ext) for ext in pathext):''
and in the traceback
''if any(cmd.lower().endswith(ext.lower()) for ext in pathext):''
do you see the difference?
see your remark above.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3837#comment:11&gt;
OK, I see what is going on now.
You are using Python 3.7. As a a result the {{{shutil_which}}} name is
[https://github.com/GRASS-GIS/grass-
ci/blob/a26ceefdc4e14edc0529b90c4d92c0122b6a4d0e/lib/python/script/core.py#L230-L231
an alias] to [https://docs.python.org/3/library/shutil.html#shutil.which
shutil.which] function
[https://github.com/python/cpython/blob/79efbb719383386051c72f2ee932eeca8e033e6b/Lib/shutil.py#L1293
defined] in the standard library.
On Python 2 though, shutil_which is the function [https://github.com
/GRASS-GIS/grass-
ci/blob/a26ceefdc4e14edc0529b90c4d92c0122b6a4d0e/lib/python/script/core.py#L160
defined] in {{{scripts/core.py}}}.
This is why there is this difference. The function in scripts.core is
never executed in Python 3.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3837#comment:12&gt;
Replying to [comment:12 pmav99]:
yes. OSGeo4W-winGRASS7.7.svn is compiled/built against Python 3.x as a
test build for preparing the upcoming OSGeo4W-winGRASS7.8
> As a a result the {{{shutil_which}}} name is [https://github.com/GRASS-
GIS/grass-
/GRASS-GIS/grass-
yes it seems so.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3837#comment:13&gt;
OK, it seems that this will be probably fixed on Python 3.8:
https://bugs.python.org/issue18283
https://github.com/python/cpython/commit/5680f6546dcda550ad70eefa0a5ebf1375303307
In the meantime, @hellik can you please try to copy paste the 3.8 version
of shutil.which from github and test if it works?
https://github.com/python/cpython/blob/d8320ecb86da8df7c13d8bf8582507f736aa2924/Lib/shutil.py#L1293-L1369
Ticket URL: <https://trac.osgeo.org/grass/ticket/3837#comment:14&gt;
Replying to [comment:14 pmav99]:
version of shutil.which from github and test if it works?
will try a copy/paste; into core.py, right?
what is missing in the 3.8 github version of shutil.which, is:
this should be added to while copy/paste
Ticket URL: <https://trac.osgeo.org/grass/ticket/3837#comment:15&gt;
> - https://bugs.python.org/issue18283
now what I've done:
* I copied ''def which'' and ''def _access_check'' (L1285-L1369) from
[https://github.com/python/cpython/commit/5680f6546dcda550ad70eefa0a5ebf1375303307
python github] into C:\OSGeo4W64\apps\Python37\lib\shutil.py
=> the wxGUI start up window to select a location/mapset pops up.
thus, the python fix for 3.8 (''shutil.which() should support bytes'')
seems to work.
then there is another issue (in
C:\OSGEO4~1\apps\Python37\lib\xml\etree\ElementTree.py), but then this may
be another ticket.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3837#comment:16&gt;
tested now with
GRASS Version: 7.7.dev
Code revision: 2929fffa9
Build date: 2019-07-19
Build platform: x86_64-w64-mingw32
GDAL: 2.4.1
PROJ.4: 5.2.0
GEOS: 3.7.2
SQLite: 3.26.0
Python: 3.7.0
wxPython: 4.0.3
Platform: Windows-10-10.0.18362-SP0 (OSGeo4W)
wxGUI opens now; closing ticket.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3837#comment:17&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: python3, py3, wingrass
Changes (by hellik):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/grass/ticket/3837#comment:18&gt;
