GDAL
May 2, 2019, 10:33am
1
#3839: r.watershed usage inconsistency
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.6.2
Component: Raster | Version: svn-trunk
Keywords: r.watershed | CPU: Unspecified
Platform: Unspecified |
r.watershed source code says
/* Check for some output map */
if ((opt8->answer == NULL)
&& (opt9->answer == NULL)
&& (opt10->answer == NULL)
&& (opt11->answer == NULL)
&& (opt12->answer == NULL)
&& (opt14->answer == NULL)
&& (opt15->answer == NULL)) {
G_fatal_error(_("Sorry, you must choose an output map."));
but there are more output raster maps defined, eg.
opt13 = G_define_standard_option(G_OPT_R_OUTPUT);
opt13->key = "length_slope";
opt13->label = _("Name for output slope length raster map");
opt13->description = _("Slope length and steepness (LS) factor for
USLE");
opt13->required = NO;
opt13->guisection = _("Outputs");
Ticket URL: <https://trac.osgeo.org/grass/ticket/3839> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
2
Resolution: | Keywords: r.watershed
Comment (by martinl):
In [changeset:"74452" 74452]:
#!CommitTicketReference repository="" revision="74452"
r.watershed usage inconsistency, see #3839
Ticket URL: <https://trac.osgeo.org/grass/ticket/3839#comment:1> ;
GDAL
May 2, 2019, 10:35am
3
Should be fixed in r74452:
r.watershed elev=dem
ERROR: At least one of the following options is required: <accumulation>,
<tci>, <spi>, <drainage>, <basin>, <stream>, <half_basin>, <length_slope>
and <slope_steepness>
Also `threshold` check improved:
r.watershed elev=dem basin=x
ERROR: Option <basin> requires <threshold>
Ticket URL: <https://trac.osgeo.org/grass/ticket/3839#comment:2> ;
GDAL
May 2, 2019, 10:36am
4
If no objection I will backport r74452 to GRASS76 release branch.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3839#comment:3> ;
GDAL
May 2, 2019, 12:43pm
5
Comment (by mmetz):
Replying to [comment:3 martinl]:
Looks good to me.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3839#comment:4> ;
