#3843: cartographic composer only previews and outputs in profile aspect (no
landscape)
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: wxGUI | Version: svn-
| releasebranch76
Keywords: cartographic composer, aspect mode | CPU: Unspecified
Platform: MacOSX |
I just discovered that the cartographic composer will not create a preview
or output PDF in landscape (horizontal) mode. You can select landscape for
composing the map. But when you go to preview or output, it reverts to
profile (vertical) mode--cutting off map features.
FWIW, it seems like landscape mode should be the default for maps anyway.
But in any case, the preview and PDF output should respect the chosen
aspect dimensions and ratios.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3843>
