#3844: Make Region importable from pygrass.gis
Reporter: pmav99 | Owner: grass-dev@…
Priority: normal | Milestone: 7.8.0
Component: PyGRASS | Version: svn-trunk
Keywords: | CPU: Unspecified
Platform: Unspecified |
Currently, in order to import the {{{Region}}} class you need to import it
from {{{pygrass.gis.region}}}. The following patch allows to import it
from the {{{pygrass.gis}}} package. This way, all gis objects can be
imported/used from the same module. E.g.
import grass.pygrass.gis as ggis
ggis.Region
ggis.Location
ggis.Mapset
The patch:
diff --git lib/python/pygrass/gis/__init__.py
index 82e176bd..2e65e990 100644
--- lib/python/pygrass/gis/__init__.py
+++ lib/python/pygrass/gis/__init__.py
@@ -9,11 +9,11 @@ import shutil
import ctypes as ct
import fnmatch
import grass.lib.gis as libgis
from grass.pygrass.errors import GrassError
from grass.script.utils import encode, decode
from grass.pygrass.utils import getenv
+from grass.pygrass.gis.region import Region
test_vector_name = "Gis_test_vector"
test_raster_name = "Gis_test_raster"
Ticket URL: <https://trac.osgeo.org/grass/ticket/3844>
