[GRASS-dev] [GRASS GIS] #3851: r.out.mpeg always fails because the output file name is empty
Reporter: paoloz | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Raster | Version: svn-trunk
Keywords: mpeg animation | CPU: Unspecified
Platform: Unspecified |
Testing r.out.mpeg using North Carolina data set, smaller subset NC
location (nc_basic_spm_grass7)
g.region rast=elevation
r.out.mpeg view1=elevation@PERMANENT,elevation_shade@PERMANENT
output=./test.mpg
always fails with
output=./test.mpg
Reading raster map <elevation@PERMANENT>...\\
Reading raster map <elevation_shade@PERMANENT>...\\
ERROR: Could not open output file! \\
WARNING: mpeg_encode ERROR
the reason is that the name of the output mpeg fie is not copied in the
"outfile" variable, which is used to write the name of the output mpeg in
the configuration file for "ppmtompeg"|"mpeg_encode" encoder. Therefore
the name of the output mpeg is blank and the encoding always fail with
"ERROR: Could not open output file!".
Tested with GRASS: 7.0.0, 7.4 svn (12/01/2018), 7.6.0, 7.6.1.
Works in 6.4.6 because the variable is not empty, see lines 442-445 of
grass-6.4.6/raster/r.out.mpeg/main.c.
A patch to solve the problem is attached.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3851&gt;
Resolution: | Keywords: mpeg animation
Changes (by paoloz):
* Attachment "r_out_mpeg.diff" added.
r.out.mpeg
Comment (by neteler):
Would you mind to submit your fix as a pull request here?
https://github.com/OSGeo/grass/pulls
We recently mirated to !GitHub for the code management and we could handle
your contribution much easier. Thanks!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3851#comment:1&gt;
Comment (by mmetz):
Replying to [comment:1 neteler]:
For the time being; i would regard a patch as a pull request. If people
are more comfortable providing a patch, that's fine.
I have applied the patch to master, relbr76, and relbr74:
https://github.com/OSGeo/grass/commit/78e9da1af300035ab1dbe4135ab79d1068aadd58
https://github.com/OSGeo/grass/commit/2340b9dc9612535a6f249557a6175c98128a7451
https://github.com/OSGeo/grass/commit/3ab95ff7a1781317dcca969c13cfe4fc6cb024df
Ticket URL: <https://trac.osgeo.org/grass/ticket/3851#comment:2&gt;
