[GRASS-dev] [GRASS GIS] #3857: r.mapcalc unable to rename null and cell files
Reporter: Hygsson | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 7.6.2
Component: Raster | Version: unspecified
Keywords: r.mapcalc | CPU: x86-64
Platform: MSWindows 7 |
**Note:** This works on Ubuntu without any problems.
While using GRASS GIS 7.6.1 on 64-bit Windows 7, I encountered a problem
with r.mapcalc. For a simple stochastic simulation of watershed, I used a
following script (here it is recreated for Spearfish dataset).
g.region raster=elevation.dem@PERMANENT
r.surf.random --overwrite output=frequency min=0 max=0
for (( n=1 ; n<21 ; n=$n+1 ))
do
         r.surf.random --overwrite output=errors min=-15 max=15
         r.mapcalc "terrain = elevation.dem@PERMANENT + errors@PERMANENT"
--overwrite
         r.watershed --overwrite elevation=terrain@PERMANENT
accumulation=accum$n
         r.reclass --overwrite input=accum$n@PERMANENT output=flow$n
rules=C:/Users/Hygsson/Desktop/test/reclass.rules
         r.mapcalc "frequency = flow$n + frequency" --overwrite
done
reclass.rules file has a following content:
-500 thru 654 = 0
* = 1
I tried to do it step by step without using the script. **The problem
arises with this step:**
I get this output for each iteration of the loop. Only numbers behind
'unknown/' are different.
WARNING: Unable to rename null file
'C:\Users\Hygsson\Documents\grassdata\Spearfish60_grass7\PERMANENT\.tmp/unknown\22368.1'
             to
'C:\Users\Hygsson\Documents\grassdata\Spearfish60_grass7\PERMANENT\cell_misc\frequency\nullcmpr':
             File exists
WARNING: Unable to rename cell file
'C:\Users\Hygsson\Documents\grassdata\Spearfish60_grass7\PERMANENT\.tmp/unknown\22368.0'
             to
'C:\Users\Hygsson\Documents\grassdata\Spearfish60_grass7\PERMANENT\fcell\frequency':
             File exists
The desired 'frequency' raster is created, but obviously in a wrong
manner, having only one value.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3857&gt;
Resolution: | Keywords: r.mapcalc
       CPU: x86-64 | Platform: MSWindows 7
Comment (by wenzeslaus):
Overwriting map you are reading from is not allowed according to the
documentation:
//A map cannot be used both as an input and as an output as in this
invalid expression `oldmap = oldmap + 1`, instead a subsequent rename
using `g.rename` is needed when the same name is desired: //
r.mapcalc "newmap = oldmap + 1"
g.rename raster=newmap,oldmap
https://grass.osgeo.org/grass76/manuals/r.mapcalc.html#using-the-same-map-
for-input-and-output-results
It may work in some cases, but it is not guaranteed. Maybe a check of the
inputs and outputs and an error message on Windows and a warning on other
platforms would be backward-compatible solution. Would you mind opening a
new ticket? On the other hand, having this feature (`a = a + 1`) seems
reasonable (but supporting it is more complex).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3857#comment:1&gt;
Comment (by hellik):
Replying to [ticket:3857 Hygsson]:
> do
--overwrite
> done
> -500 thru 654 = 0
> * = 1
> to
> File exists
> to
> File exists
it is an operating system issue/feature/limitation of MS windows, that you
are not able to read and write the same file at the same time.
therefore it's not a winGRASS bug.
as Vaclav already mentioned, it may work in linux, but it's not garanteed
that it always work in every linux.
so I tend to a ''won't fix'' of the ticket.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3857#comment:2&gt;
      Type: defect | Status: closed
Resolution: wontfix | Keywords: r.mapcalc
Changes (by Hygsson):
* status: new => closed
* resolution: => wontfix
Comment:
OK, thank you for your replies. It's good to know that the issue is on
Windows' side. I am therefore closing this ticket and will open a new one
regarding that input/output check suggested by Wenzeslaus.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3857#comment:3&gt;
Comment (by glynn):
Replying to [comment:2 hellik]:
you are not able to read and write the same file at the same time.
By itself, that wouldn't be an issue. GRASS raster output doesn't modify
files in-place, but creates a temporary file which is renamed into place
by Rast_close(). But r.mapcalc doesn't close the input maps, so their
cell/fcell/null files are still open when the output maps are closed. A
fix **might** be as simple as calling close_maps() from
[source:grass/trunk/raster/r.mapcalc/evaluate.c#L396 execute()], before
The temporary file is used for cell, fcell and null files. Other files are
modified in-place, but these are normally either closed before raster I/O
starts or opened after raster I/O has completed.
Aside: this is why G_tempfile() creates files in the mapset, not /tmp or
$TMPDIR; they have to be on the same filesystem as the mapset so that
rename() works.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3857#comment:4&gt;
Comment (by Nikos Alexandris):
I read this thread again and I am still not happy with the "it may work in
some cases" statement. In which cases will it work and in which not? Can
someone help to dig out the "documented" behavior?
Glynn's suggested fix is applied here:
https://github.com/OSGeo/grass/blob/master/raster/r.mapcalc/evaluate.c#L395.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3857#comment:5&gt;
Comment (by glynn):
Replying to [comment:5 Nikos Alexandris]:
in some cases" statement. In which cases will it work and in which not?
Can someone help to dig out the "documented" behavior?
With that fix, it should work so long as the maps are actual GRASS maps,
not external files linked via r.external(.out).
Things which might still be an issue:
* Overwriting a map doesn't systematically delete files belonging to the
old map. Look at
[https://github.com/OSGeo/grass/blob/master/lib/raster/close.c#369
close_new] to see which files are removed or replaced. This issue isn't
specific to r.mapcalc, or to overwriting outputs with inputs, but with
overwriting in general.
* When copying a map without any intervening calculation (i.e. the entire
expression on the right-hand side of a top-level assignment is just a map,
optionally with a neighbourhood modifier, but no category/colour
modifier), the input map's categories, colours and history are copied to
the output map. This won't work if the input map and output map are the
same map, and it won't work reliably if the input map is one of the
outputs (the result will depend upon the order in which the outputs are
closed). Closing an output map will replace all of the standard support
files (see close_new as mentioned above), so copying those files will copy
the new version if the output map has already been closed. This situation
doesn't seem particularly likely to occur in practice.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3857#comment:6&gt;
