[GRASS-dev] [GRASS GIS] #3866: i.spec.unmix: endmember pixels do not sum up to 100%
Reporter: neteler | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Imagery | Version: unspecified
Keywords: i.spec.unmix | CPU: Unspecified
Platform: Unspecified |
While the endmember maps of i.pysptools.unmix sum up to 100%, those of
i.spec.unmix apparently don't.
GRASS 7.7.dev (nc_spm_08_grass7):~ >
g.region raster=lsat7_2002_10 -p
# requires https://github.com/OSGeo/grass/pull/39
g.extension i.pysptools.unmix
g.extension i.spec.unmix
# auto-generate endmember matrix and endmember maps
i.pysptools.unmix input=lsat_2002 endmembers=endmembers endmember_n=5 \
    output=spectrum.txt prefix=lsat_spectra --v
# check data range (here: not reflectance), e.g.
r.info -r lsat7_2002_10
min=42
max=255
r.info -r lsat7_2002_40
min=1
max=255
# check created spectrum.txt
cat spectrum.txt
# Channels: lsat7_2002_10 lsat7_2002_20 lsat7_2002_30 lsat7_2002_40
lsat7_2002_50 lsat7_2002_70 lsat7_2002_80
# Wrote 5 spectra line wise.
Matrix: 5 by 7
row0: 68.0 44.0 30.0 2.0 1.0 4.0 13.0
row1: 73.0 64.0 37.0 182.0 92.0 34.0 117.0
row2: 133.0 123.0 140.0 79.0 250.0 255.0 161.0
row3: 255.0 239.0 255.0 141.0 156.0 98.0 250.0
row4: 255.0 255.0 255.0 221.0 255.0 214.0 22.0
# derive endmember maps from spectrum.txt
# hypothesis: endmember maps should be similar to those generated by
i.pysptools.unmix
i.spec.unmix group=lsat_2002 matrix=spectrum.txt result=lsat7_2002_unmix \
    error=lsat7_2002_unmix_err iter=lsat7_2002_unmix_iterations
# hypothesis: sum of all endmember maps should sum up to 100 (%):
r.mapcalc "all_unmix = lsat7_2002_unmix.1 + lsat7_2002_unmix.2 +
lsat7_2002_unmix.3 + lsat7_2002_unmix.4 + lsat7_2002_unmix.5 -
lsat7_2002_unmix_err"
r.univar -e -g all_unmix
min=-100
max=71
range=171
mean=21.3971956456606
first_quartile=18
median=22
third_quartile=25
percentile_90=28
... indeed, the sum is far from the expectation of SUM(endmembers) = 100%.
The addon i.spec.unmix is relevant because it expects known endmembers as
input which is important for a defined analysis (while i.pysptools.unmix
apparently always auto-generates the endmembers which are not necessarily
the best or those the user wants).
I suspect a bug in i.spec.unmix (maybe just a scaling issue internally?).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3866&gt;
