v.import is using v.in.ogr but most of v.in.ogr options are missing, I
would like to add them (or at least some of them), the missing options
have not been added for some reasons or could I work on it?
Replying to [ticket:3869 lucadelu]:
> Hi devs,
v.import is (was) meant to be an easy to use module with a simple
interface for importing vector data. The idea was that if you want more
control or more options you can use the more advanced module v.in.ogr.
Replying to [comment:1 mmetz]:
I fully understand, but my request is for a better user experience. I was
at JRC for a meeting about INSPIRE support and I discovered a really
useful option to use in gdal_doo to have a better support for GML files. I
think it is important to have this capability also in v.import for example
Replying to [comment:2 lucadelu]:
> [...] I was at JRC for a meeting about INSPIRE support and I discovered
a really useful option to use in gdal_doo to have a better support for GML
files. I think it is important to have this capability also in v.import
for example
The gdal_doo option is IMHO an advanced option: you need to know to the
OGR driver needed to read this dataset, and you need to read the GDAL/OGR
documentation for this particular driver to know which dataset open
options (or GDAL configuration options) are needed to properly read this
particular dataset.
Thinking about it, it is ok to provide all options of v.in.ogr and v.proj
also in v.import, as long as they go into separate gui sections, something
like "advanced".
Maybe there should be a gui section "dangerous" for the v.in.ogr -o flag
and the v.import options epsg and datum_trans.
Considering the substantial changes in PROJ 6+, it might no longer be
possible to do fully automated reprojection, instead users need in some
cases select the appropriate reprojection method for their particular
data: there can be several methods available to transform coordinates from
one CRS to another CRS, users have to decide which one to use. Just as a
warning that v.import might not work as expected with proj 6+ and gdal 3+
in future releases of GRASS GIS.
