#3874: Encode error in g.extension, add-ons not written in GUI
Reporter: veroandreo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.8.0
Component: Addons | Version: svn-trunk
Keywords: | CPU: x86-64
Platform: Linux |
I just compiled grass77 in a colleague's Linux Mint 19.1 Cinamon laptop
following the instructions here:
https://grasswiki.osgeo.org/wiki/Compile_and_Install#Linux_Mint
All is fine, but when we install **any** add-on, we get:
g.extension r.seasons
Fetching <r.seasons> from GRASS GIS Addons repository (be patient)...
Compiling...
Installing...
Updating addons metadata file...
Updating private addons metadata file...
File "/home/carla/software/grass-7.7.git/dist.x86_64-pc-linux-
gnu/scripts/g.extension", line 1933, in <module>
sys.exit(main())
gnu/scripts/g.extension", line 1913, in main
install_extension(source=source, url=url, xmlurl=xmlurl)
gnu/scripts/g.extension", line 704, in install_extension
blist = install_private_extension_xml(tmp_dir, mlist)
gnu/scripts/g.extension", line 1006, in install_private_extension_xml
write_xml_modules(xml_file, tree)
gnu/scripts/g.extension", line 603, in write_xml_modules
(' ' * indent, tnode.find('keywords').text))
UnicodeEncodeError: 'ascii' codec can't encode character u'\xe1' in
position 19: ordinal not in range(128)
GRASS 7.7.dev (nc_basic_spm_grass7):~ > g.extension extension=v.class.mlR
Fetching <v.class.mlR> from GRASS GIS Addons repository (be patient)...
Compiling...
Installing...
sys.exit(main())
UnicodeEncodeError: 'ascii' codec can't encode character u'\xf3' in
position 29: ordinal not in range(128)
The add-on is indeed installed, but it is not added to the list of
extensions in the GUI. I cannot reproduce any of this in my Fedora box
with freshly re-compiled grass77 with locale in English.
Locale is in Spanish for Argentina, but there's no special characters in
her user:
LANG=es_AR
LANGUAGE=es_AR
LC_CTYPE=es_AR.UTF-8
LC_NUMERIC=C
LC_TIME=es_AR.UTF-8
LC_COLLATE=es_AR.UTF-8
LC_MONETARY=es_AR.UTF-8
LC_MESSAGES=es_AR.UTF-8
LC_PAPER=es_AR.UTF-8
LC_NAME=es_AR.UTF-8
LC_ADDRESS=es_AR.UTF-8
LC_TELEPHONE=es_AR.UTF-8
LC_MEASUREMENT=es_AR.UTF-8
LC_IDENTIFICATION=es_AR.UTF-8
LC_ALL=
System info:
Versión de GRASS: 7.7.dev
Code revision: fca1b4079
Fecha de compilación: 2019-07-18
Construir plataforma: x86_64-pc-linux-gnu
GDAL: 2.2.3
PROJ.4: 4.9.3
GEOS: 3.6.2
SQLite: 3.22.0
Python: 2.7.15+
wxPython: 3.0.2.0
Plataforma: Linux-4.15.0-54-generic-x86_64-with-LinuxMint-19.1-tessa
ps: she is also getting an encode/decode error when trying to display a
raster from GUI:
'ascii' codec can't decode byte 0xc3 in position 17: ordinal not in
range(128)
however, she accepts the error and the raster is displayed anyway...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3874>
