[GRASS-dev] [GRASS GIS] #3875: GRASS doesn't start with non-system locale
Reporter: annakrat | Owner: grass-dev@…
     Type: defect | Status: new
Priority: critical | Milestone: 7.6.2
Component: Default | Version: svn-trunk
Keywords: init script | CPU: Unspecified
Platform: All |
When setting different locale, GRASS session doesn't start:
   File "./bin.x86_64-pc-linux-gnu/grass77", line 2204, in <module>
     main()
   File "./bin.x86_64-pc-linux-gnu/grass77", line 2082, in main
     message(_("Starting GRASS GIS..."))
NameError: global name '_' is not defined
Appeared after
[https://github.com/OSGeo/grass/commit/2246f5b6aca7a3dca67fc8b0d0c46fe64be39626
2246f5b].
Ticket URL: <https://trac.osgeo.org/grass/ticket/3875&gt;
Resolution: | Keywords: init script
       CPU: Unspecified | Platform: All
Comment (by marisn):
To reproduce the issue it is necessary to set language override to some
language with unsupported locale.
Thus the full output is:
Failed to enforce user specified language 'ru' with error: 'unsupported
locale setting'
A LANGUAGE environmental variable has been set.
Part of messages will be displayed in the requested language.
   File "bin.x86_64-pc-linux-gnu/grass77", line 2204, in <module>
     main()
   File "bin.x86_64-pc-linux-gnu/grass77", line 2082, in main
Ticket URL: <https://trac.osgeo.org/grass/ticket/3875#comment:1&gt;
Comment (by hellik):
windows 10 box with german locale, switching winGRASS to english, wxGUI
starts, though some warning:
Error: Reading settings from file
<C:\Users\myuser\AppData\Roaming\GRASS7\wx> failed.
                 Details: not enough values to unpack (expected 2, got 1)
                 Line: ''
switching to ru, wxGUI starts and the GUI is partly in russian, though the
same warning:
                 Line: ''
tested with
System Info
GRASS version: 7.7.dev
Code revision: 5249e44ac
Build date: 2019-07-24
Build platform: x86_64-w64-mingw32
GDAL: 2.4.1
PROJ.4: 5.2.0
GEOS: 3.7.2
SQLite: 3.26.0
Python: 3.7.0
wxPython: 4.0.3
Platform: Windows-10-10.0.18362-SP0 (OSGeo4W)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3875#comment:2&gt;
Comment (by annakrat):
Replying to [comment:2 hellik]:
but that's before the commit that caused this
Ticket URL: <https://trac.osgeo.org/grass/ticket/3875#comment:3&gt;
  Priority: blocker | Milestone: 7.6.2
Changes (by annakrat):
* priority: critical => blocker
Comment:
Looks like it happens on Mac without special locale setting
Ticket URL: <https://trac.osgeo.org/grass/ticket/3875#comment:4&gt;
Please test if this PR fixes the issue:
https://github.com/OSGeo/grass/pull/156
Ticket URL: <https://trac.osgeo.org/grass/ticket/3875#comment:5&gt;
      Type: defect | Status: closed
  Priority: blocker | Milestone: 7.8.1
Component: Default | Version: git-releasebranch78
Resolution: fixed | Keywords: init script
Changes (by neteler):
* status: new => closed
* version: svn-trunk => git-releasebranch78
* resolution: => fixed
* milestone: 7.6.2 => 7.8.1
Comment:
PR applied in
- master:
https://github.com/OSGeo/grass/commit/63d08250621d74bc7d43b8d87ba6d635f4763a54
- relbranch78:
https://github.com/OSGeo/grass/commit/25835a286ea70f80bb5745ffb0c0d0dd728f7927
Closing, reopen if needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3875#comment:6&gt;
