GDAL
August 11, 2019, 4:40pm
1
#3885: wxGUI no longer shows start image
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.8.0
Component: wxGUI | Version:
Keywords: g.gui | CPU: Unspecified
Platform: Unspecified |
When starting `g.gui` in G78dev only a kind of empty frame is shown
(really, some graphic memory garbage of the window behind if present)
while it works ok in master.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3885> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
August 11, 2019, 7:55pm
2
Resolution: | Keywords: g.gui
Comment (by mmetz):
Replying to [ticket:3885 neteler]:
Not reproducible on Fedora 30, please `make distclean`, check `git
status`, then recompile.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3885#comment:1> ;
GDAL
August 12, 2019, 4:32pm
3
Comment (by veroandreo):
I have the same issue reported in a freshly re-compiled grass79 in Fedora
30 (I use make distclean).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3885#comment:2> ;
GDAL
August 12, 2019, 6:30pm
4
If I start in text mode, and then call GUI with `g.gui`, then the start
image displays normally and with the same message as described above...
so, no idea
Ticket URL: <https://trac.osgeo.org/grass/ticket/3885#comment:3> ;
GDAL
August 18, 2019, 2:11pm
5
Comment (by neteler):
At startup (using relbr78), I see these error messages:
/home/mneteler/software/grass78_git/dist.x86_64-pc-linux-
gnu/gui/wxpython/wxgui.py:101: DeprecationWarning: Yield() is deprecated
wx.Yield()
16:09:21: Debug: Adding duplicate image handler for 'Windows bitmap file'
Ticket URL: <https://trac.osgeo.org/grass/ticket/3885#comment:4> ;
GDAL
August 19, 2019, 2:30am
6
Comment (by annakrat):
I can't reproduce on Ubuntu. Are you sure that it works in master? If yes,
it shouldn't be that hard to figure out the specific commit causing it.
Replying to [comment:4 neteler]:
> wx.Yield()
file'
file'
It's not error, just warnings and debug, I think I get these too, so they
don't have to mean anything.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3885#comment:5> ;
GDAL
August 19, 2019, 1:07pm
7
Description changed by neteler:
Old description:
New description:
System description:
System Info
GRASS version: 7.8.dev
Code revision: a50165153
Build date: 2019-08-12
Build platform: x86_64-pc-linux-gnu
GDAL: 2.3.2
PROJ.4: 5.2.0
GEOS: 3.7.1
SQLite: 3.26.0
Python: 3.7.4
wxPython: 4.0.4
Platform: Linux-5.2.8-200.fc30.x86_64-x86_64-with-fedora-30-Thirty
Ticket URL: <https://trac.osgeo.org/grass/ticket/3885#comment:6> ;
GDAL
August 19, 2019, 1:08pm
8
Replying to [comment:5 annakrat]:
yes, it shouldn't be that hard to figure out the specific commit causing
it.
After reboot it works in both master and relbranch78.
It seems to be a fuzzy problem
Ticket URL: <https://trac.osgeo.org/grass/ticket/3885#comment:7> ;
GDAL
October 23, 2019, 6:46am
9
Type: defect | Status: closed
Priority: normal | Milestone: 7.8.1
Component: wxGUI | Version: git-releasebranch78
Resolution: fixed | Keywords: g.gui
Changes (by neteler):
* status: new => closed
* version: => git-releasebranch78
* resolution: => fixed
Comment:
Fixed in master and release_branch_7_8. Closing
Ticket URL: <https://trac.osgeo.org/grass/ticket/3885#comment:9> ;
