#3886: Importing vector training areas in g.gui.iclass (interactive)
Reporter: pshapley | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Imagery | Version: svn-releasebranch76
Keywords: | CPU: x86-64
Platform: Linux |
The 'g.gui.iclass' module in 7.6.1 64bit stable version (ubuntu 18.04) GUI
interface does not allow 'import training areas from vector map' when I
attempt this Grass will instantly crash. On the cmdline (non-interactive)
module option I get the error below.
10:49:01: Debug: ScreenToClient cannot work when toplevel
window is not shown
window is not shown
window is not shown
window is not shown
window is not shown
Loading raster map <JPEG2000_composite@PERMANENT>...
Loading training map
<drainedbarepeat_signature@PERMANENT>...
window is not shown
window is not shown
G__open(read): Unable to open '/home/xxxx/Documents/TempLoc
ation_DO_NOT_DELETE/PERMANENT/.tmp/xxxx
OptiPlex-7010/vector/trAreas226970/frmt': No such file or
directory
GUI interface does not allow 'import training areas from vector map' when
I attempt this Grass will instantly crash. On the cmdline (non-
interactive) module option I get the error below.
window is not shown
window is not shown
window is not shown
window is not shown
window is not shown
window is not shown
window is not shown
directory
New description:
window is not shown
window is not shown
window is not shown
window is not shown
window is not shown
window is not shown
window is not shown
directory
Priority: normal | Milestone: 7.8.3
Component: wxGUI | Version: git-releasebranch78
Resolution: | Keywords: g.gui.iclass
CPU: x86-64 | Platform: Linux
Comment (by neteler):
I can confirm this in G78:
# tested with NC zipcode map, just to trigger the error
g.gui.iclass
'/home/mneteler/grassdata/nc_spm_08/user1/.tmp/oboe/vector/trAreas11066050/frmt':
No such file or directory
