[GRASS-dev] [GRASS GIS] #3890: Extend v.in.ogr to use GDAL/OGR-GMLAS driver
Reporter: gisix | Owner: grass-dev@…
Priority: normal | Milestone:
Component: Vector | Version: svn-trunk
Keywords: | CPU: Unspecified
Platform: Unspecified |
GDAL/OGR features a new extended driver for complex GML-data which
currently can't be accessed from a GRASS environment. This driver (GMLAS)
extends the run-of-the-mill GML-capabilities available to GRASS users
significantly. Please add parameters/flags for v.in.ogr to make use of
this GDAL functionality.
best,
Peter
Ticket URL: <https://trac.osgeo.org/grass/ticket/3890&gt;
      Type: enhancement | Status: closed
Resolution: invalid | Keywords:
Changes (by mmetz):
* status: new => closed
* resolution: => invalid
Comment:
v.in.ogr can import any data formats supported by GDAL/OGR, no special
parameters/flags needed. For example, if GDAL/OGR supports GMLAS, GMLAS
data can be imported, granted that the contents are supported by GRASS.
Note that the contents are not GMLAS specific.
GMLAS test data of GDAL/OGR at
https://github.com/OSGeo/gdal/tree/master/autotest/ogr/data/gmlas/real_world
are imported just fine.
Closing as invalid, please reopen if there is need for particular
parameters/flags related to GMLAS.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3890#comment:1&gt;
Comment (by gisix):
Please reopen this ticket and reconsider whether this is really invalid
for GIS users wanting to work with nontrivial contemporary 3D GML in GRASS
GIS:
1) GDAL as it is currently configured in GRASS 7.6.1 does *NOT* include
the GMLAS driver for nontrivial GML/XML. So v.in.ogr currently does *NOT*
import nontrivial GML/XML: Opening a complex GML-based file like european
CityGML datasets by explicitly choosing the advanced GMLAS driver instead
of the default GML driver throws an error message. If folks want to work
with complex 3D GML, they will need to do so outside a GRASS environment.
2) The GMLAS driver of GDAL/OGR would allow to work in GRASS with 3D
PolyhedralSurfaces encoded as nontrivial GML.
3)3D PolyhedralSurfaces will either either require functionality for the
users on the GRASS module level (i.e. a flag or similar for v.in.ogr) to
flatten 3D polyhedral surfaces into a GRASS 2D vector topology,
4) or a means to provide additional parameters to the underlying GDAL/OGR
environment, similar to the query_layer parameter of v.to.db
(https://grass.osgeo.org/grass70/manuals/v.to.db.html)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3890#comment:2&gt;
Comment (by mmetz):
Replying to [comment:2 gisix]:
GDAL is *NOT* configured in GRASS, GDAL is independent of GRASS. That
means if a particular OGR driver is available in OGR or not is independent
of GRASS, there is nothing GRASS can do about it. Please compile GDAL from
source or contact the maintainer of the GDAL package for your operating
system.
No, there is no mechanism in GRASS to convert PolyhedralSurfaces to
another geometry type. You can try `ogr2ogr -nlt MULTIPOLYGONZ`, see
https://gdal.org/programs/ogr2ogr.html, but as mentioned in the link in
https://lists.osgeo.org/pipermail/grass-user/2019-August/080599.html,
"Note that converting a TIN or a PolyhedralSurface into a MultiPolygon is
semantically incorrect since a MultiPolygon is supposed to contain
geometries in the same plane, but it might help when converting those new
geometry types into a format that doesn’t support them", converting a
PolyhedralSurface into a MultiPolygon is technically possible, at the risk
of getting garbage. Note that PolyhedralSurfaces are not restricted to
GMLAS, they are a new geometry type of simple features supported by a few
data formats like GMLAS.
As above, technically possible at the risk of getting garbage, try
`ogr2ogr -nlt MULTIPOLYGONZ` instead. IMHO it is a bad idea to make
v.in.ogr convert otherwise valid data into potential garbage.
GDAL/OGR environment, similar to the query_layer parameter of v.to.db
Already implemented in v.in.ogr with the options gdal_config and gdal_doo.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3890#comment:3&gt;
