[GRASS-dev] [GRASS GIS] #39: r.in.srtm fails to validate zip files
Reporter: kyngchaos | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.3.0
Component: default | Version: unspecified
Keywords: |
r.in.srtm uses "file -ib" on the zip file to check if it has the correct
mime type. "-i" seems to be a very ambiguous way to specify the mime
flag. The BSD version of file (at least on OSX) uses "-i" for the "do no
classify" regular files option, and "-I" (uppercase) for the mime option,
though has "-i" for mime listed as a legacy option. GNU file and old UNIX
versions use "-i" for the mime option. SUS does not have mime as a
minimum option to support.
It looks like all have the extended "--mime" flag. Attached is a patch
to use that flag. There should probably be a way to handle the
possibility of a system having a "file" command without any mime flag, but
I don't know how to handle that, and it may not be critical.
Ticket URL: <http://trac.osgeo.org/grass/ticket/39&gt;
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
Resolution: | Keywords:
Comment (by hamish):
could 'unzip -t' help?
what does the IEEE standard say about the -i `file` option?
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/39#comment:1&gt;
Comment (by kyngchaos):
I don't know why it was changed ([19303]), but it used to try unzipping
immediately, and testing whether that failed. "unzip -t" tests by
unzipping anyways before the real unzipping, thus wasting time (though it
is only in memory).
Ticket URL: <http://trac.osgeo.org/grass/ticket/39#comment:2&gt;
Interesting - I was wondering why I didn't notice this before, I know I've
converted SRTM since that change. I totally forgot to check older OSX
versions. OSX 10.5 has "-I" as the mime flag. OSX 10.4, and probably
previous versions, has "-i" as the mime flag.
> what does the IEEE standard say about the -i file option?
Dunno, but the SUS standard (which OSX 10.5 now conforms to) has "-i" as
the "do not classify regular files" option.
[http://en.wikipedia.org/wiki/File_(Unix)#Usage]
Ticket URL: <http://trac.osgeo.org/grass/ticket/39#comment:3&gt;
I guess my main concerns are:
  * the "--mime" flag is standard on modern systems - it looks like it.
  * I've noticed that people tend to avoid the double-dash long versions of
flags, but I don't know if there is a technical reason other than less
typing. In this case it avoids confusion in the -i/-I short flag.
If there are no objections to "--mime", I'll patch r.in.srtm.
Ticket URL: <http://trac.osgeo.org/grass/ticket/39#comment:4&gt;
I'd suggest skipping the use of "file" altogether. It isn't a standard
utility on Windows.
I would assume that the filename ending in .zip is at least prima
facie evidence of the file actually being a ZIP file.
Makes sense. I wonder why it was changed in the past? It used to try unzipping and check if it failed. Markus?
http://trac.osgeo.org/grass/changeset/19303
utility on Windows.
grass-dev mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
  Reporter: kyngchaos | Owner: hamish
      Type: defect | Status: assigned
Changes (by hamish):
  * status: new => assigned
  * owner: grass-dev@lists.osgeo.org => hamish
* cc: grass-dev@lists.osgeo.org (added)
Comment:
SUS says:
   http://www.opengroup.org/onlinepubs/009695399/utilities/file.html
--mime is not mentioned.
re "why was it changed" in r19303: it never used `zip` to test, it was
using `ls` to look for a file with a .zip extension. (input= refers to the
tile name not the file name)
-ls -1 "$FILE.hgt.zip" | grep zip > /dev/null
-if [ $? -ne 0 ] ; then
+# really a ZIP file?
+if [ "`file -ib $FILE.hgt.zip`" != "application/x-zip" ] ; then
    echo "$FILE.hgt.zip is no zip file."
    exit 1
  fi
for one thing "echo $foo.zip | grep zip" was always true.
Perhaps the reason for the test had to do with downloaders creating
incomplete or 0 byte files, or having wrongly named files?
I've removed `file` and added a call to `unzip -t` in 6.3 trunk.
waiting to backport to 6.3.0's branch and close the bug until someone
tests the change please.
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/39#comment:5&gt;
see r30046
Ticket URL: <http://trac.osgeo.org/grass/ticket/39#comment:6&gt;
Comment:
SUS says:
    exit 1
  fi
If incomplete downloads are an issue, file probably won't help if you
manage to download anything at all, as it normally only checks the
first few bytes of the file. My /usr/share/misc/file/magic file has:
# ZIP archives (Greg Roelofs, c/o zip-bugs@wkuvx1.wku.edu)
0 string PK\003\004
4 byte 0x09 Zip archive data, at least v0.9 to extract
4 byte 0x0a Zip archive data, at least v1.0 to extract
4 byte 0x0b Zip archive data, at least v1.1 to extract
4 byte 0x14
30 ubelong !0x6d696d65 Zip archive data, at least v2.0 to extract
0x161 string WINZIP Zip archive data, WinZIP self-extracting
This suggests that the first 8 bytes are sufficient in most cases, 34
bytes for v2.0, or 360 bytes for a self-extracting archive.
"unzip -vb" would probably be enough to catch aborted downloads. ZIP
files have the catalog at the end of the file, so a truncated file
would normally lack a catalog.
Hamish:
> was using `ls` to look for a file with a .zip extension. (input=
> refers to the tile name not the file name)
oops, wrong. that was used as a 'if [ -f ${FILE}.zip ] ;' test.
Not like echo as the file wasn't guaranteed to be there.
> creating incomplete or 0 byte files, or having wrongly named files?
No, the module built the input filename internally, and was checking
that it came up with a correct filename. Getting mime type from `file`
was just a more advanced form of that.
Glynn:
probably not. It will exit with an error if the unzip step fails.
and I think that should be fine.
> someone tests the change please.
Hamish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
      Type: defect | Status: closed
Resolution: fixed | Keywords:
  * status: assigned => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/39#comment:7&gt;
