#3909: Consistent variable names: r.import and r.proj
Reporter: rshepard | Owner: grass-dev@…
Priority: normal | Milestone: 8.0.0
Component: Projections/Datums | Version: svn-trunk
Keywords: resample, method, interpolation | CPU: x86-64
Platform: Linux |
r.import has a an option called resample which defines the resampling
method to use. r.proj has an option called method which defines the
interpolation method to be used.
Seems to me that resamplig == interpolation and I recommend changing the
r.import veriable name from 'resample' to 'method' for consistency. After
all, they list the same transformation types.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3909>
