[GRASS-dev] [GRASS GIS] #3921: GUI fails to start if rc contains missing mapset
Reporter: marisn | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: wxGUI | Version: svn-trunk
Keywords: | CPU: Unspecified
Platform: Linux |
I removed a mapset I was using as the last one. Thus my .grass7/rc file
was pointing to a non-existing mapset. On next attempt to start GRASS, I
got only an error:
Starting GRASS GIS...
ERROR: Error in GUI startup. See messages above (if any) and if necessary,
please report this error to the GRASS developers.
On systems with package manager, make sure you have the right GUI package,
probably named grass-gui, installed.
To run GRASS GIS in text mode use the --text flag.
Use '--help' for further options
      grass79 --help
See also: https://grass.osgeo.org/grass79/manuals/helptext.html
Exiting...
As you can see, there are no reasonable error messages. GRASS should be
able to cope with fact that mapset, locale or gisdbase gas gone missing
since the last run as rc file is just for convenience.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3921&gt;
  Priority: normal | Milestone: 7.8.1
Resolution: | Keywords:
       CPU: Unspecified | Platform: Linux
Changes (by marisn):
* milestone: => 7.8.1
Comment:
Pull request with a fix: https://github.com/OSGeo/grass/pull/167
Ticket URL: <https://trac.osgeo.org/grass/ticket/3921#comment:1&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by neteler):
* status: new => closed
* resolution: => fixed
Comment:
Merged:
- master:
https://github.com/OSGeo/grass/commit/78a004cb64ffd7062aa3c960534e69b3922add01
- relbranc78:
https://github.com/OSGeo/grass/commit/657ef28a2b44f951a1322d6c4f6a40abf3780f28
Closing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3921#comment:2&gt;
