#3934: wxGUI: Python error on "Set color table interactively" tool
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.8.1
Component: wxGUI | Version: git-releasebranch78
Keywords: python3, colors | CPU: Unspecified
Platform: Unspecified |
When using right mouse menu on a raster map to run the interactive color
tool, the following error appears:
File "/home/mneteler/software/grass78_git/dist.x86_64-pc-
linux-gnu/gui/wxpython/modules/colorrules.py", line 981, in
OnSelectionInput
'max': self.properties['max']})
TypeError
%d format: a number is required, not NoneType
/home/mneteler/software/grass78_git/dist.x86_64-pc-linux-
gnu/gui/wxpython/modules/colorrules.py:1986:
wxPyDeprecationWarning: Call to deprecated item
BitmapFromImage. Use :class:`wx.Bitmap` instead
bitmap = wx.BitmapFromImage(img)
