[GRASS-dev] [GRASS GIS] #3937: Histogram tool in the GUI: save button gives error
Reporter: veroandreo | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: wxGUI | Version: svn-trunk
Keywords: histogram | CPU: Unspecified
Platform: Linux |
When I try to save the histogram generated by the histograming tool from
the GUI, I get the following:
/home/veroandreo/software/grass79-dev/dist.x86_64-pc-linux-
gnu/gui/wxpython/gui_core/wxlibplot.py:609:
wxPyDeprecationWarning: Using deprecated class. Use Cursor
instead.
   self.HandCursor = wx.CursorFromImage(Hand.GetImage())
gnu/gui/wxpython/gui_core/wxlibplot.py:611:
instead.
   self.GrabHandCursor =
wx.CursorFromImage(GrabHand.GetImage())
gnu/gui/wxpython/gui_core/wxlibplot.py:615:
instead.
   self.MagCursor = wx.CursorFromImage(MagPlus.GetImage())
   File
"/home/veroandreo/software/grass79-dev/dist.x86_64-pc-linux-
gnu/gui/wxpython/wxplot/base.py", line 483, in SaveToFile
self.client.SaveFile()
   File
gnu/gui/wxpython/gui_core/wxlibplot.py", line 733, in
SaveFile
fType = _string.lower(fileName[-3:])
AttributeError
module 'string' has no attribute 'lower'
and I can't save the plot.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3937&gt;
  Priority: normal | Milestone: 7.8.2
Resolution: | Keywords: histogram
       CPU: Unspecified | Platform: Linux
Changes (by neteler):
* milestone: => 7.8.2
Comment:
This wxPyDeprecationWarning also shows up when simply plotting a
histogram.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3937#comment:1&gt;
Comment (by annakrat):
This should be fixed now in master. It might still give you a warning,
which is a problem in wx fixed in latest version. Please test, I plan to
backport it.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3937#comment:2&gt;
Comment (by neteler):
Excellent, the original problem is fixed, thanks!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3937#comment:3&gt;
Comment (by veroandreo):
I just updated and the original problem is gone, thanks :slight_smile:
I just observed a different (maybe related) issue. When I use "Create
histogram with d.histogram" from the GUI and try to save it, the output is
either not created and GUI crashes or, the dialog saying "please wait,
exporting image..." never disappears...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3937#comment:4&gt;
That's a different issue, looking into this.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3937#comment:5&gt;
This was little bit more tricky, but should be fixed in master, could you
please test?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3937#comment:6&gt;
works fine now :slight_smile:
I leave open in case it needs backport
Ticket URL: <https://trac.osgeo.org/grass/ticket/3937#comment:7&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: histogram
Changes (by annakrat):
* status: new => closed
* resolution: => fixed
Comment:
Backported.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3937#comment:8&gt;
