#3947: v.in.ascii: add second warning about import of files without category
column
Reporter: jidanni | Owner: grass-dev@…
Priority: trivial | Milestone:
Component: Docs | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
On man v.in.ascii after
Import of files without category column If the input file does not
contain a category column, there is the possibility to auto-generate these
IDs (categories). To automatically add an additional column named 'cat',
the cat parameter must be set to the virtual column number 0 (cat=0). This
is the default action if the cat parameter is not set.
add an additional warning that these will be **unique** categories. In
fact: 1, 2, 3...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3947>
