#3949: Number examples
Reporter: jidanni | Owner: grass-dev@…
Priority: minor | Milestone:
Component: Docs | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
$ w3m -dump file:///usr/share/doc/grass-doc/html/v.segment.html | grep
^Example
Example: Extract line segment from 400m to 5000m from beginning of line 1:
Example: Create parallel 1km long line segments along first 8km of track,
Example: A series of points, spaced every 2km along the tracks
Example: A series of points, spaced every 2km along the tracks, offset
500m to
Example: A series of points, spaced every 10% of the line's length along
the
These should be called Example 1, Example 2, etc. with their own Table
of Contents entries too.
In fact just like is already implemented on v.in.ascii.html !
Thanks, but I am talking about real ''numbered'' examples. Just like in a
textbook.
Only then can one say, "Professor, regarding example 3A..."
Even when just looking at a g.manual -m man page too!
$ GET https://raw.githubusercontent.com/OSGeo/grass/c97c8beaeb66540a8cbd5c679bbd49de2a75c724/vector/v.segment/v.segment.html
| grep -i Example
<h2>EXAMPLES</h2>
The examples are based on the North Carolina sample location.
$ GET https://grass.osgeo.org/grass79/manuals/v.in.ascii.html | grep
Example
<li class="toc"><a href="#example-1a)---standard-format-mode"
class="toc">Example 1a) - standard format mode</a></li>
<li class="toc"><a href="#example-1b)---standard-format-mode"
class="toc">Example 1b) - standard format mode</a></li>
<li class="toc"><a href="#example-2---point-format-mode"
class="toc">Example 2 - point format mode</a></li>
<li class="toc"><a href="#example-3---point-format-mode"
class="toc">Example 3 - point format mode</a></li>
<li class="toc"><a href="#example-4---point-format-mode---csv-
table" class="toc">Example 4 - point format mode - CSV table</a></li>
<li class="toc"><a href="#example-5---point-format-mode"
class="toc">Example 5 - point format mode</a></li>
<li class="toc"><a href="#example-6---point-format-mode"
class="toc">Example 6 - point format mode</a></li>
<li class="toc"><a href="#example-7---point-format-mode"
class="toc">Example 7 - point format mode</a></li>
<li class="toc"><a href="#example-8---point-format-mode"
class="toc">Example 8 - point format mode</a></li>
<h3><a name="example-1a)---standard-format-mode">Example 1a) - standard
format mode</a></h3>
<h3><a name="example-1b)---standard-format-mode">Example 1b) - standard
<h3><a name="example-2---point-format-mode">Example 2 - point format
mode</a></h3>
<h3><a name="example-3---point-format-mode">Example 3 - point format
mode</a></h3>
<h3><a name="example-4---point-format-mode---csv-table">Example 4 - point
format mode - CSV table</a></h3>
<h3><a name="example-5---point-format-mode">Example 5 - point format
mode</a></h3>
<h3><a name="example-6---point-format-mode">Example 6 - point format
mode</a></h3>
<h3><a name="example-7---point-format-mode">Example 7 - point format
mode</a></h3>
<h3><a name="example-8---point-format-mode">Example 8 - point format
mode</a></h3>
