#396: add NULL and MASK support to i.smap
Reporter: dylan | Owner: grass-dev@…
Priority: minor | Milestone: 7.8.0
Component: Raster | Version:
Resolution: | Keywords: i.smap
CPU: Other | Platform: All
Changes (by marisn):
* milestone: 6.4.6 => 7.8.0
Comment:
This still is a case.
To make things worse – if NULL cells are inside a block, result differs
significantly from a different sized block without NULL cells. Thus maps
with NULL values should use as small blocks as possible.
Ticket URL: <https://trac.osgeo.org/grass/ticket/396#comment:2>
