[GRASS-dev] [GRASS GIS] #3962: GRASS 7.8.1 GUI doesn't run on Pop! OS 18.04 (Ubuntu 18.04) because of "ImportError: cannot import name 'NewIdRef'"
Reporter: rorschach | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.8.2
Component: wxGUI | Version: git-releasebranch78
Keywords: | CPU: x86-64
Platform: Linux |
Hi everyone,
I installed GRASS 7.8.1 via the ubuntugis-unstable repository on my
machine running Pop! OS 18.04 (based on Ubuntu 18.04). When I run GRASS,
this error occurs:
Starting GRASS GIS...
   File "/usr/lib/grass78/gui/wxpython/gis_set.py", line 43, in <module>
     from startup.guiutils import SetSessionMapset, NewMapsetDialog
   File "/usr/lib/grass78/gui/wxpython/startup/guiutils.py", line 25, in
<module>
     from gui_core.dialogs import TextEntryDialog
   File "/usr/lib/grass78/gui/wxpython/gui_core/dialogs.py", line 50, in
<module>
     from gui_core.gselect import LocationSelect, MapsetSelect, Select, \
   File "/usr/lib/grass78/gui/wxpython/gui_core/gselect.py", line 64, in
<module>
     from gui_core.widgets import ManageSettingsWidget,
CoordinatesValidator
   File "/usr/lib/grass78/gui/wxpython/gui_core/widgets.py", line 92, in
<module>
     from gui_core.wrap import Button, SearchCtrl, StaticText, StaticBox, \
   File "/usr/lib/grass78/gui/wxpython/gui_core/wrap.py", line 39, in
<module>
     from wx import NewIdRef as NewId
ERROR: Error in GUI startup. See messages above (if any) and if necessary,
please report this error to the GRASS developers.
On systems with package manager, make sure you have the right GUI package,
probably named grass-gui, installed.
To run GRASS GIS in text mode use the --text flag.
Use '--help' for further options
      grass78 --help
See also: https://grass.osgeo.org/grass78/manuals/helptext.html
Exiting...
I checked the module in question (wx). The said module isn't available on
the default Python (python2) of my machine.
Python 2.7.15+ (default, Oct 7 2019, 17:39:04)
[GCC 7.4.0] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import wx
   File "<stdin>", line 1, in <module>
ImportError: No module named wx
It is however available on my machine's Python 3.
Python 3.6.8 (default, Oct 7 2019, 12:59:55)
[GCC 8.3.0] on linux
>>> import wx
>>> wx.__version__
'4.0.1'
When I try to import NewIdRef, it doesn't exist but NewId does.
>>> import wx
Finally, GRASS text mode works. It really is just the GUI that fails.
Thanks everyone!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3962&gt;
Resolution: | Keywords:
       CPU: x86-64 | Platform: Linux
Comment (by neteler):
Unfortunately we missed to backport this PR:
  https://github.com/OSGeo/grass/pull/155
There are two options now:
  * fix the Python file on your machine as per PR 155, or
  * wait for the GRASS GIS 7.8.2 release
See also the related discussion here:
https://lists.osgeo.org/pipermail/grass-user/2019-November/081028.html
(and later in the thread)
I'd close this report as fixed...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3962#comment:1&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by rorschach):
* status: new => closed
* resolution: => fixed
Comment:
Thank you for the prompt response, Markus, and for pointing me to the PR.
I was wondering how I should edit the problematic file in the beginning.
I edited the Python file
(''/usr/lib/grass78/gui/wxpython/gui_core/wrap.py'') to match that of PR
155 and the GUI now works.
I'll go ahead and resolve this issue as fixed.
Sincerely,
Ben Hur
Ticket URL: <https://trac.osgeo.org/grass/ticket/3962#comment:2&gt;
