GDAL
November 17, 2019, 6:10pm
1
#3966: Batch job examples: add GRASS_PAGER=cat to avoid getting stuck expecting a
terminal
Reporter: jidanni | Owner: grass-dev@…
Priority: trivial | Milestone:
Component: Docs | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
On https://grass.osgeo.org/grass79/manuals/grass7.html be sure to add an
GRASS_PAGER=cat grass --exec g.list type=all
example, else some batch job will be ruined due to /usr/bin/pager's
WARNING: terminal is not fully functional
- (press RETURN)
As some commands, e.g., g.list, are thus booby-trapped, while others,
e.g., v.info map=abc, will not trigger the "bug".
Ticket URL: <https://trac.osgeo.org/grass/ticket/3966> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
November 17, 2019, 6:12pm
2
terminal
Resolution: | Keywords:
Comment (by jidanni):
< else some batch job will be ruined
> else some batch jobs will be ruined
Ticket URL: <https://trac.osgeo.org/grass/ticket/3966#comment:1> ;
GDAL
December 6, 2019, 5:19pm
3
terminal
Comment (by wenzeslaus):
Any idea how to reproduce this with interactive job for testing purposes?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3966#comment:2> ;
GDAL
December 6, 2019, 8:24pm
4
terminal
Resolution: | Keywords: exec batch grass.py
Changes (by wenzeslaus):
* keywords: => exec batch grass.py
Ticket URL: <https://trac.osgeo.org/grass/ticket/3966#comment:3> ;
GDAL
December 8, 2019, 3:06am
5
terminal
Gee I only use GRASS from makefiles... not the GUI, so do not know.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3966#comment:4> ;
GDAL
February 22, 2023, 5:28pm
6
terminal
Priority: trivial | Milestone: 7.8.3
I would even say a change in the source code is more appropriate if we
understand the issue more, but I'm not able to reproduce this.
The following ones behave as expected:
grass --tmp-location XY --exec g.list type=all
nohup grass --tmp-location XY --exec g.list type=all
true | (setsid grass --tmp-location XY --exec g.list type=all) 2>&1 | cat
echo "grass --tmp-location XY --exec g.list type=all" > /tmp/test.sh
nohup bash /tmp/test.sh
Only `bash /tmp/test.sh` will jump into an interactive pager which may be
little unexpected, but I'm in an interactive terminal, so perhaps
inconvenient, but not unexpected.
I'm closing this and we can discuss this in a new issue on GitHub if
needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3966#comment:6> ;
GDAL
February 22, 2023, 5:29pm
7
terminal
Type: enhancement | Status: closed
Resolution: worksforme | Keywords: exec batch grass.py
* status: new => closed
* resolution: => worksforme
Ticket URL: <https://trac.osgeo.org/grass/ticket/3966#comment:7> ;
