#3972: Every single doc page has raw 'Last changed: $Date$' still stuck in it
Reporter: jidanni | Owner: grass-dev@…
Type: defect | Status: new
Priority: minor | Milestone:
Component: Docs | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
Every single doc page has this raw 'Last changed: $Date$' stuck in it
$ w3m -dump https://grass.osgeo.org/grass79/manuals/helptext.html | fgrep
which make zero sense to the reader.
Resolution: | Keywords:
Comment (by jidanni):
< which make zero sense to the reader.
> which makes zero sense to the reader.
Perhaps just strip it off, until the fix is confirmed.
Type: defect | Status: closed
Priority: minor | Milestone: 7.8.2
Component: Docs | Version: git-releasebranch78
Resolution: fixed | Keywords:
Comment (by Bas Couwenberg):
You can use `$Format:%ci$` in the file and mark such files with `export-
subst` in `.gitattributes`.
From `gitattributes(5)`:
> `export-subst`
> If the attribute `export-subst` is set for a file then Git
will expand several placeholders when adding this file to an archive. The
expansion depends on the availability of a commit ID, i.e., if `git-
archive(1)` has been
> given a tree instead of a commit or a tag then no replacement
will be done. The placeholders are the same as those for the option
`--pretty=format`: of `git-log(1)`, except that they need to be wrapped
like this:
> `$Format:PLACEHOLDERS$` in the file. E.g. the string
`$Format:%H$` will be replaced by the commit hash.
