GDAL
November 18, 2019, 8:47am
1
#3975: g.manual -m gives ERROR: No manual page entry
Reporter: jidanni | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Docs | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
man xyz works.
g.manual xyz works.
g.manual -m xyz says ERROR: No manual page entry for xyz.
At least here on Debian sid.
GRASS 7.8.1 (newLocation):~ > g.manual -m g.manual
ERROR: No manual page entry for 'g.manual'
GRASS 7.8.1 (newLocation):~ > g.manual -m d.vect
ERROR: No manual page entry for 'd.vect'
GRASS 7.8.1 (newLocation):~ > g.manual -i
GRASS 7.8.1 (newLocation):~ > g.manual -i -m
ERROR: No manual page entry for 'index'
GRASS 7.8.1 (newLocation):~ > g.manual -t -m
ERROR: No manual page entry for 'topics'
GRASS 7.8.1 (newLocation):~ > g.manual g.manual
Ticket URL: <https://trac.osgeo.org/grass/ticket/3975> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
November 18, 2019, 3:04pm
2
Priority: normal | Milestone: 7.8.2
Component: Docs | Version: git-releasebranch78
Resolution: | Keywords: Debian
Changes (by neteler):
* keywords: => Debian
* version: unspecified => git-releasebranch78
* milestone: => 7.8.2
Comment:
Works nicely on Fedora:
g.manual(1) Grass User's
Manual g.manual(1)
NAME
g.manual - Displays the manual pages of GRASS modules.
KEYWORDS
general, manual, help
The manual pages are expected to be under
/usr/lib64/grass78/docs/man/man1/x.yyy.1
see path in
https://github.com/OSGeo/grass/blob/master/scripts/g.manual/g.manual.py#L101
Perhaps stores the MAN pages elsewhere?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3975#comment:1> ;
GDAL
November 18, 2019, 3:20pm
3
Comment (by Bas Couwenberg):
Manpages have the 'grass' suffix appended to the section to prevent
conflicts, see:
https://salsa.debian.org/debian-gis-
team/grass/blob/debian/7.8.1-1/debian/rules#L150
Ticket URL: <https://trac.osgeo.org/grass/ticket/3975#comment:2> ;
GDAL
November 18, 2019, 4:59pm
4
Comment (by neteler):
Replying to [comment:2 Bas Couwenberg]:
conflicts, see:
I see a "grass7.1" in the line
team/grass/blob/debian/7.8.1-1/debian/rules#L151
maybe that's the problem?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3975#comment:3> ;
GDAL
November 18, 2019, 5:15pm
5
No, that just renames `grass7.1` to `grass78.1`.
Which is not the case on Debian:
$ apt-file search man1/g.manual.1
grass-doc: /usr/share/man/man1/g.manual.1grass.gz
So `g.manual.py` needs to be patched to test the `.1grass` section suffix
instead of just `.1`, this is more in line with what `man(1)` does, as it
has no issue to find manpages with `.1foo` suffixes:
$ man -w g.manual
Ticket URL: <https://trac.osgeo.org/grass/ticket/3975#comment:4> ;
GDAL
November 18, 2019, 7:17pm
6
Something like this may be a good solution:
--- a/g.manual 2019-11-18 20:06:17.402073322 +0100
+++ b/g.manual 2019-11-18 20:16:03.794093319 +0100
@@ -46,6 +46,7 @@
#% required : yes
#%end
+import subprocess
import sys
import os
@@ -98,6 +99,19 @@
def start_man(entry):
+ try:
+ cmd = ['man', '-w', '1', entry]
+ process = subprocess.Popen(cmd, stdout=subprocess.PIPE,
stderr=subprocess.PIPE)
+ (stdout, stderr) = process.communicate()
+ paths = stdout.decode().split('\n')
+ if os.path.exists(paths[0]):
+ os.execlp('man', 'man', paths[0])
+ except Exception:
+ pass
path = os.path.join(gisbase, 'docs', 'man', 'man1', entry + '.1')
if not os.path.exists(path) and os.getenv('GRASS_ADDON_BASE'):
path = os.path.join(os.getenv('GRASS_ADDON_BASE'), 'docs', 'man',
Ticket URL: <https://trac.osgeo.org/grass/ticket/3975#comment:5> ;
