[GRASS-dev] [GRASS GIS] #3979: G79: problem with i.sentinel.import and importer.write_metadata()
Reporter: neteler | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Imagery | Version: svn-trunk
Keywords: i.sentinel.import, image | CPU: Unspecified
  collections |
Platform: Unspecified |
I was trying to import Sentinel-2 (S2-L1C) data into G78 in order to make
use of image collections:
i.sentinel.import input=/mnt/geodata/openeo_bolzano/
register_output=s2_t_register.csv
Processing <T32TPS_20180608T101021_B02>...
Importing raster map <T32TPS_20180608T101021_B02>...
100%
Processing <T32TPS_20180608T101021_B12>...
Importing raster map <T32TPS_20180608T101021_B12>...
100%
Processing <T32TPS_20180608T101021_B07>...
Importing raster map <T32TPS_20180608T101021_B07>...
100%
Processing <T32TPS_20180608T101021_B11>...
Importing raster map <T32TPS_20180608T101021_B11>...
100%
Processing <T32TPS_20180608T101021_B10>...
Importing raster map <T32TPS_20180608T101021_B10>...
100%
Processing <T32TPS_20180608T101021_B03>...
Importing raster map <T32TPS_20180608T101021_B03>...
100%
Writing metadata to maps...
File "/root/.grass7/addons/scripts/i.sentinel.import", line 504, in
<module>
sys.exit(main())
File "/root/.grass7/addons/scripts/i.sentinel.import", line 488, in main
File "/root/.grass7/addons/scripts/i.sentinel.import", line 407, in
write_metadata
meta = ip_meta[ip]
KeyError: 'S2B_MSIL1C_20180613T101019_N0206_R022_T32TPS_20180613T122213'
I am using a rasther fresh version:
g.version -rge
version=7.9.dev
date=2019
revision=exported
build_date=2019-11-19
build_platform=x86_64-pc-linux-gnu
build_off_t_size=8
libgis_revision=00000
libgis_date="?"
proj=4.9.3
gdal=2.2.3
geos=3.6.2
sqlite=3.22.0
Ticket URL: <https://trac.osgeo.org/grass/ticket/3979&gt;
Sorry, I am on it.
Fra: grass-dev grass-dev-bounces@lists.osgeo.org på vegne av GRASS GIS trac@osgeo.org
Sendt: onsdag 20. november 2019 22:19
Kopi: grass-dev@lists.osgeo.org grass-dev@lists.osgeo.org
Emne: [GRASS-dev] [GRASS GIS] #3979: G79: problem with i.sentinel.import and importer.write_metadata()
collections |
Processing <T32TPS_20180608T101021_B02>…
Importing raster map <T32TPS_20180608T101021_B02>…
100%
Processing <T32TPS_20180608T101021_B12>…
Importing raster map <T32TPS_20180608T101021_B12>…
100%
Processing <T32TPS_20180608T101021_B07>…
Importing raster map <T32TPS_20180608T101021_B07>…
100%
Processing <T32TPS_20180608T101021_B11>…
Importing raster map <T32TPS_20180608T101021_B11>…
100%
Processing <T32TPS_20180608T101021_B10>…
Importing raster map <T32TPS_20180608T101021_B10>…
100%
Processing <T32TPS_20180608T101021_B03>…
Importing raster map <T32TPS_20180608T101021_B03>…
100%
Writing metadata to maps…
File “/root/.grass7/addons/scripts/i.sentinel.import”, line 504, in
sys.exit(main())
File “/root/.grass7/addons/scripts/i.sentinel.import”, line 488, in main
File “/root/.grass7/addons/scripts/i.sentinel.import”, line 407, in
write_metadata
meta = ip_meta[ip]
KeyError: ‘S2B_MSIL1C_20180613T101019_N0206_R022_T32TPS_20180613T122213’
g.version -rge
version=7.9.dev
date=2019
revision=exported
build_off_t_size=8
libgis_date=“?”
proj=4.9.3
gdal=2.2.3
geos=3.6.2
sqlite=3.22.0
Ticket URL: <https://trac.osgeo.org/grass/ticket/3979>
Resolution: | Keywords: i.sentinel.import, image
       CPU: | collections
  Unspecified | Platform: Unspecified
Comment (by sbl):
Please test: https://github.com/OSGeo/grass-addons/pull/65
I could not reproduce the error with that particular S2 scene, but got
deprecation warnings from xml on Fedora 30.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3979#comment:1&gt;
       CPU: | collections
Comment (by neteler):
Thanks for your efforts but still...:
  100%
   File "/root/.grass7/addons/scripts/i.sentinel.import", line 503, in
<module>
     sys.exit(main())
   File "/root/.grass7/addons/scripts/i.sentinel.import", line 487, in main
   File "/root/.grass7/addons/scripts/i.sentinel.import", line 406, in
write_metadata
     meta = ip_meta[ip]
GRASS 7.9.dev (utm32n_32632): >
Ticket URL: <https://trac.osgeo.org/grass/ticket/3979#comment:2&gt;
       CPU: | collections
I added the pdb debugger there:
> /root/.grass7/addons/scripts/i.sentinel.import(407)write_metadata()
-> meta = ip_meta[ip]
(Pdb) ip
'S2A_MSIL1C_20180608T101021_N0206_R022_T32TPS_20180608T135059'
(Pdb) ip_meta[ip]
{'timestamp': datetime.datetime(2018, 6, 8, 10, 17, 26, 568000),
'SATELLITE': 'S2A', 'CLOUDY_PIXEL_PERCENTAGE': '63.2363',
'DEGRADED_MSI_DATA_PERCENTAGE': '0', 'ZENITH_ANGLE_0': '6.87463083682177',
'AZIMUTH_ANGLE_0': '106.678480338394', 'ZENITH_ANGLE_9':
'6.92095256322843', 'AZIMUTH_ANGLE_9': '106.766469213864',
'ZENITH_ANGLE_10': '6.6711378900598', 'AZIMUTH_ANGLE_10':
'106.075220597716', 'ZENITH_ANGLE_1': '6.60472703969214',
'AZIMUTH_ANGLE_1': '105.531721669131', 'ZENITH_ANGLE_2':
'6.64725248700114', 'AZIMUTH_ANGLE_2': '105.80797975942',
'ZENITH_ANGLE_3': '6.69114850385045', 'AZIMUTH_ANGLE_3':
'106.033552825819', 'ZENITH_ANGLE_4': '6.72593186902208',
'AZIMUTH_ANGLE_4': '106.198282849613', 'ZENITH_ANGLE_5':
'6.76337836610513', 'AZIMUTH_ANGLE_5': '106.292239966037',
'ZENITH_ANGLE_6': '6.79969827918603', 'AZIMUTH_ANGLE_6':
'106.408451382071', 'ZENITH_ANGLE_7': '6.62125461003938',
'AZIMUTH_ANGLE_7': '105.678569152871', 'ZENITH_ANGLE_8':
'6.83898070776319', 'AZIMUTH_ANGLE_8': '106.505396826378',
'ZENITH_ANGLE_11': '6.74365826507417', 'AZIMUTH_ANGLE_11':
'106.342330082536', 'ZENITH_ANGLE_12': '6.83298026030892',
'AZIMUTH_ANGLE_12': '106.566283022332', 'MEAN_SUN_ZENITH_GRID_ANGLE':
26.24232325141777, 'MEAN_SUN_AZIMUTH_GRID_ANGLE': 149.15294328922496,
'MEAN_SUN_ZENITH_ANGLE': '26.2423240875397', 'MEAN_SUN_AZIMUTH_ANGLE':
'149.1529063561'}
No idea - I don't see the issue
Ticket URL: <https://trac.osgeo.org/grass/ticket/3979#comment:3&gt;
       CPU: | collections
Comment (by sbl):
That`s odd indeed. I cannot reproduce the error with exactly the same
scene and both trunk and 7.8 on Fedora 30.
With an older version of trunk:
g.version -rge
version=7.9.dev
date=2019
revision=400349708
build_date=2019-08-31
build_off_t_size=8
libgis_date="?"
proj4=5.2.0
gdal=2.3.2
geos=3.7.1
sqlite=3.26.0
as well as a fresh compiled one and 7.8.1:
g.version -rge
version=7.8.1RC1
date=2019
revision=exported
build_date=2019-11-11
build_platform=x86_64-redhat-linux-gnu
build_off_t_size=8
libgis_date="?"
proj=5.2.0
gdal=2.3.2
geos=3.7.1
sqlite=3.26.0
I have no issues with i.sentinel.import with that scene.
Maybe the download was not 100% OK?
Do you have other scenes in that directory?
BTW, does 7.8 support band references?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3979#comment:4&gt;
       CPU: | collections
My system here is based on the mundialis GRASS GIS 7.9/PDAL/Python 3
docker image (Ubuntu).
I have added, since it is a key error, added a print statement:
WARNING: Raster map <T32TPS_20180608T101021_B03> already exists and will
be
          overwritten
  100%
dict_keys(['timestamp', 'SATELLITE', 'CLOUDY_PIXEL_PERCENTAGE',
'DEGRADED_MSI_DATA_PERCENTAGE', 'ZENITH_ANGLE_0', 'AZIMUTH_ANGLE_0',
'ZENITH_ANGLE_9', 'AZIMUTH_ANGLE_9', 'ZENITH_ANGLE_10', '
AZIMUTH_ANGLE_10', 'ZENITH_ANGLE_1', 'AZIMUTH_ANGLE_1', 'ZENITH_ANGLE_2',
'AZIMUTH_ANGLE_2', 'ZENITH_ANGLE_3', 'AZIMUTH_ANGLE_3', 'ZENITH_ANGLE_4',
'AZIMUTH_ANGLE_4', 'ZENITH_ANGLE_5', 'AZIM
UTH_ANGLE_5', 'ZENITH_ANGLE_6', 'AZIMUTH_ANGLE_6', 'ZENITH_ANGLE_7',
'AZIMUTH_ANGLE_7', 'ZENITH_ANGLE_8', 'AZIMUTH_ANGLE_8', 'ZENITH_ANGLE_11',
'AZIMUTH_ANGLE_11', 'ZENITH_ANGLE_12', 'AZIMUT
H_ANGLE_12', 'MEAN_SUN_ZENITH_GRID_ANGLE', 'MEAN_SUN_AZIMUTH_GRID_ANGLE',
'MEAN_SUN_ZENITH_ANGLE', 'MEAN_SUN_AZIMUTH_ANGLE'])
'AZIMUTH_ANGLE_10', 'ZENITH_ANGLE_1', 'AZIMUTH_ANGLE_1', 'ZENITH_ANGLE_2',
'AZIMUTH_ANGLE_4', 'ZENITH_ANGLE_5', 'AZIMUTH_ANGLE_5', 'ZENITH_ANGLE_6',
'AZIMUTH_ANGLE_6', 'ZENITH_ANGLE_7', 'AZIMUTH_ANGLE_7', 'ZENITH_ANGLE_8',
'AZIMUTH_ANGLE_8', 'ZENITH_ANGLE_11', 'AZIMUTH_ANGLE_11',
'ZENITH_ANGLE_12', 'AZIMUTH_ANGLE_12', 'MEAN_SUN_ZENITH_GRID_ANGLE',
'MEAN_SUN_AZIMUTH_GRID_ANGLE', 'MEAN_SUN_ZENITH_ANGLE',
   File "/root/.grass7/addons/scripts/i.sentinel.import", line 505, in
<module>
     sys.exit(main())
   File "/root/.grass7/addons/scripts/i.sentinel.import", line 489, in main
write_metadata
     meta = ip_meta[ip]
PS: No, 7.8.x does not contain image collection support.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3979#comment:5&gt;
       CPU: | collections
Comment (by martinl):
What is content of `/mnt/geodata/openeo_bolzano/` dir?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3979#comment:6&gt;
       CPU: | collections
Replying to [comment:6 martinl]:
root@d07d7993f8ce:/src/actinia_core# ls -la /mnt/geodata/openeo_bolzano/
total 5083276
drwxr-xr-x 7 root root 4096 Nov 21 10:42 .
drwxr-xr-x 13 1002 1002 4096 Nov 19 12:09 ..
-rw-r--r-- 1 1002 1002 98304 Nov 19 12:07 openeo_bolzano.gpkg
-rw-r--r-- 1 root root 778891069 Nov 19 12:10
S2A_MSIL1C_20180608T101021_N0206_R022_T32TPS_20180608T135059.zip
-rw-r--r-- 1 root root 666971053 Nov 19 12:10
S2A_MSIL1C_20180611T102021_N0206_R065_T32TPS_20180611T123241.zip
drwxr-xr-x 7 root root 4096 Nov 19 12:31
S2A_MSIL1C_20180618T101021_N0206_R022_T32TPS_20180618T135619.SAFE
-rw-r--r-- 1 root root 855084777 Nov 19 12:10
S2A_MSIL1C_20180618T101021_N0206_R022_T32TPS_20180618T135619.zip
S2A_MSIL1C_20180621T102021_N0206_R065_T32TPS_20180621T140615.SAFE
-rw-r--r-- 1 root root 800185372 Nov 19 12:10
S2A_MSIL1C_20180621T102021_N0206_R065_T32TPS_20180621T140615.zip
S2B_MSIL1C_20180606T102019_N0206_R065_T32TPS_20180606T172808.SAFE
-rw-r--r-- 1 root root 730499111 Nov 19 12:10
S2B_MSIL1C_20180606T102019_N0206_R065_T32TPS_20180606T172808.zip
drwxr-xr-x 5 root root 4096 Nov 19 12:34
S2B_MSIL1C_20180613T101019_N0206_R022_T32TPS_20180613T122213.SAFE
-rw-r--r-- 1 root root 574563063 Nov 19 12:11
S2B_MSIL1C_20180613T101019_N0206_R022_T32TPS_20180613T122213.zip
S2B_MSIL1C_20180616T102019_N0206_R065_T32TPS_20180616T154713.SAFE
-rw-r--r-- 1 root root 798910322 Nov 19 12:11
S2B_MSIL1C_20180616T102019_N0206_R065_T32TPS_20180616T154713.zip
-rw-r--r-- 1 root root 434 Nov 19 11:58 s2_L1C_scenes.csv
Ticket URL: <https://trac.osgeo.org/grass/ticket/3979#comment:7&gt;
       CPU: | collections
Comment (by sbl):
Hm, I think I have a hunch. Can you try to
1) delete all SAFE directories (or use a different unzip dir)
2) run i.sentinel.import again and see if the error remains?
If you don`t link (l-flag) the unpacked SAFE dirs should actually be
removed automatically...
If they are present, i.sentinel.import does not unpack again (anymore
after my changes). If an import is interrupted it may lead to issues like
yours...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3979#comment:8&gt;
       CPU: | collections
Replying to [comment:8 sbl]:
Bingo! Now it ran through, finally.
I didn't use -l this time.
yours...
I see. May I suggest that, if present, the SAFE directory be actually
removed before unpacking? Less confusion :slight_smile:
Rationale: it may happen then a `i.sentinel.import` job is interrupted, be
by the user, for disk-full reasons or whatever else might occur...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3979#comment:9&gt;
       CPU: | collections
Comment (by sbl):
OK, I see three options:
1) revert to old behavior
2) add a flag for not unziping again
3) use GDALs /vsizip/ virtual file system (no unzipping)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3979#comment:10&gt;
       CPU: | collections
Comment (by sbl):
OK, for the time being I solved it with a new flag (-n) for not unzipping
again. So old behavior is restored (see updated PR:
https://github.com/OSGeo/grass-addons/pull/65).
However, I would prefer using /vsizip// and reading from zip as a default
instead of unpacking at all. That would save disk space and be more
efficient in many (most?) cases.
Unless one wants to link data and use them frequently (e.g. linking L2A
products and use them without any further pre-processing) repeatedly...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3979#comment:11&gt;
