#3981: winGRASS: defining a new location by EPSG code: TypeError: invalid result
from TransList.OnMeasureItem(), an integer is required (got type NoneType)
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.8.2
Component: wxGUI | Version: git-
| releasebranch78
Keywords: wingrass, py3, python3, proj6 | CPU: x86-64
Platform: MSWindows |
when defining a new location in the location wizard by an EPSG code, I get
following message in the winGRASS-OSGEo4W shell:
TypeError: invalid result from TransList.OnMeasureItem(), an integer is
I think I am banging my head on this error #3981
I posted my problem to grass-user, but no response.
Is there a possible workaround for me?
Zoltan.
On 2019/12/02 11:49, Zoltan Szecsei wrote:
I’m using EPSG 2932 and QGIS etc all are OK with it.
I have installed everything using OSGeo4W64, so how come Grass does not use the same projections database (as QGis etc)?
(and please can I have a pointer as to how to introduce EPSG 2932 to Grass 7.8.1)
Thanks and regards,
Zoltan
******** Running against: D:\GDBroad_tiles\shp_road_poly_few\23103770_road_poly.shp
WARNING: Datum <Qatar_National_Datum_1995> not recognised by GRASS and no parameters found
Check if OGR layer <23103770_road_poly> contains polygons…
Creating attribute table for layer <23103770_road_poly>…
WARNING: Name <23103770_road_poly> is not SQL compliant. Must start with a letter.
Importing 28 features (OGR layer <23103770_road_poly>)…
Component: wxGUI | Version: git-releasebranch78
Resolution: | Keywords: wingrass, py3, python3, proj6
CPU: x86-64 | Platform: MSWindows
Comment (by annakrat):
[https://github.com/OSGeo/grass/pull/233](https://github.com/OSGeo/grass/pull/233)
grass-dev mailing list
[grass-dev@lists.osgeo.org](mailto:grass-dev@lists.osgeo.org)
[https://lists.osgeo.org/mailman/listinfo/grass-dev](https://lists.osgeo.org/mailman/listinfo/grass-dev)
