GDAL
November 25, 2019, 3:23am
1
#3996: Allow multiple --exec's
Reporter: jidanni | Owner: grass-dev@…
Priority: trivial | Milestone:
Component: Startup | Version: git-releasebranch78
Keywords: | CPU: Unspecified
Platform: Unspecified |
Enhancement idea:
Even though one can run whole shell scripts,
how about also allowing more than one "grass --exec"?
Perhaps allow multiple --exec's using Unix find(1)'s method:
-exec ... ... \; -exec ... ... \;
In fact it one fails, don't run the rest, just like Unix.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3996> ;
GRASS GIS <https://grass.osgeo.org >
GDAL
November 25, 2019, 3:44am
2
Resolution: | Keywords:
Comment (by mankoff):
Somewhat related - you can use HEREDOCs:
grass -c template.tif ./G --exec <<EOF
r.external input=foo.tif output=foo
r.out.gdal input=foo output=bar.tif
EOF
Ticket URL: <https://trac.osgeo.org/grass/ticket/3996#comment:1> ;
GDAL
November 25, 2019, 3:49am
3
Comment (by jidanni):
Replying to [comment:1 mankoff]:
Great to know, and **should be documented**.
(Alas I am mainly doing one-liners in Makefiles.)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3996#comment:2> ;
GDAL
November 25, 2019, 3:51am
4
HEREDOCs work in Makefiles.
This seems like a bad idea https://stackoverflow.com/questions/5873025
/heredoc-in-a-makefile
Ticket URL: <https://trac.osgeo.org/grass/ticket/3996#comment:3> ;
GDAL
November 25, 2019, 4:10am
5
Replying to [comment:3 mankoff]:
> This seems like a bad idea...
Yup, and that's why I learned perl while the other kids learned python. At
least good old ";"'s still work.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3996#comment:4> ;
GDAL
November 25, 2019, 11:29pm
6
Resolution: | Keywords: exec grass.py init
Changes (by wenzeslaus):
* keywords: => exec grass.py init
Comment:
Replying to [comment:2 jidanni]:
It does not work in a way, at least I think, it should work, so that's
partially the reason it is not in documentation. There is actually a
ticket for it: #2639 , so I suggest have further discussion on this there
(if needed).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3996#comment:5> ;
GDAL
November 30, 2019, 7:17pm
7
Comment (by wenzeslaus):
Back to the `--exec ... \; --exec ... \;` enhancement:
Before somebody dives into implementing this. Do you want to elaborate on
the syntax, use cases, examples, edge cases, and similarities (and
differences) to other tools besides //find//. That would be good to have
before committing to support additional syntax when there are other ways
to achieve the same (for example, aforementioned here document, an `.sh`
script, or `--exec bash -c "... ; ...;"`.)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3996#comment:6> ;
