[GRASS-dev] [GRASS GIS] #3999: Mention projection of current location in error message
Reporter: jidanni | Owner: grass-dev@…
Priority: trivial | Milestone:
Component: Projections/Datums | Version: git-releasebranch78
Keywords: | CPU: Unspecified
Platform: Unspecified |
$ grass --exec v.in.ogr -j input=e.geojson
WARNING: Projection of dataset does not appear to match current location.
          Dataset PROJ_INFO is:
          datum: wgs84
          ellps: wgs84
          proj: ll
          no_defs: defined
          ERROR: proj
OK, it says
- Dataset PROJ_INFO is:
so it also should say
- Current location is:
even if the result is unknown (say so.) Yes even if the user forgot to run
it inside grass.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3999&gt;
  Priority: trivial | Milestone: 7.8.3
Resolution: | Keywords:
Comment (by neteler):
The projection non-/matching messages have been improved in
https://github.com/OSGeo/grass/pull/317
Is it ok now?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3999#comment:2&gt;
Comment (by jidanni):
Probably. I can't test for the next few months. So close this bug if it is
OK now.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3999#comment:3&gt;
      Type: enhancement | Status: closed
Resolution: fixed | Keywords:
Changes (by neteler):
* status: new => closed
* resolution: => fixed
Comment:
Ok, I'll close for now, feel free to reopen as needed with more tests.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3999#comment:4&gt;
Comment (by mmetz):
Replying to [comment:4 neteler]:
It should be re-opened or referenced by a new issue on github because in
this particular case, a XY location, nothing has changed in the messages,
the location projection is not reported. Modules to be fixed are
r.in.gdal, r.external, v.in.ogr, v.external.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3999#comment:5&gt;
      Type: enhancement | Status: reopened
* status: closed => reopened
* resolution: fixed =>
Comment:
See new https://github.com/OSGeo/grass/pull/368
Ticket URL: <https://trac.osgeo.org/grass/ticket/3999#comment:6&gt;
