#4001: grass78 --config broken
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.8.2
Component: Python | Version: git-releasebranch78
Keywords: grass.py | CPU: Unspecified
Platform: Unspecified |
Should should be caught more gracefully:
grass78 --config
x86_64-pc-linux-gnu
./configure --with-cxx --enable-largefile --with-proj --with-proj-
share=/usr/share/proj --with-gdal=/usr/bin/gdal-config --with-python
--with-geos --with-sqlite --with-nls --with-zstd --with-pdal --with-cairo
--with-cairo-ldflags=-lfontconfig --with-freetype --with-freetype-
includes=/usr/include/freetype2 --with-wxwidgets --with-fftw --with-
postgres --with-postgres-includes=/usr/include/pgsql --with-blas --with-
blas-includes=/usr/include/atlas-x86_64-base/ --with-lapack --with-lapack-
includes=/usr/include/atlas-x86_64-base/ --with-netcdf --without-motif
--without-bzlib --without-mysql --without-odbc --without-openmp --without-
ffmpeg
gcc
/home/mneteler/software/grass78_git/dist.x86_64-pc-linux-gnu
File "/home/mneteler/bin/grass78", line 2025, in main
index = sys.argv.index(batch_exec_param)
ValueError: '--exec' is not in list
During handling of the above exception, another exception occurred:
File "/home/mneteler/bin/grass78", line 2216, in <module>
main()
File "/home/mneteler/bin/grass78", line 2030, in main
params = parse_cmdline(sys.argv[1:], default_gui=default_gui)
File "/home/mneteler/bin/grass78", line 1951, in parse_cmdline
print_params()
File "/home/mneteler/bin/grass78", line 1862, in print_params
"%s\n" % val[0].split(':')[1].rstrip('$"\n').strip())
IndexError: list index out of range
It also applies to master.
Ticket URL: <https://trac.osgeo.org/grass/ticket/4001>
