#4005: i.sentinel.mask: use raster based approach for shadow detection
Reporter: sbl | Owner: grass-dev@…
Priority: normal | Milestone:
Component: Addons | Version: unspecified
Keywords: i.sentinel.mask | CPU: Unspecified
Platform: Unspecified |
Detection of cloud shadows can be quite time consuming at times, esp. with
many clouds and shadows in an image.
The performance of the process could be improved by orders of magnitude,
if a raster based approach (r.reclass.area + r.region + r.stats) would be
used, instead of going through vector data (r.to.vect + v.clean +
v.transform + v.to.db).
In most cases, a raster mask is needed anyway in the processing chain
downstreams...
Ticket URL: <https://trac.osgeo.org/grass/ticket/4005>
