#4014: v.krige addon: ImportError: cannot import name '_' from 'core.utils'
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Addons | Version: unspecified
Keywords: v.krige | CPU: Unspecified
Platform: Unspecified |
There is a Python 3 (?) related problem in
v.krige
Loading dependencies, please wait...
R[write to console]: rgdal: version: 1.4-8, (SVN revision 845)
Geospatial Data Abstraction Library extensions to R successfully loaded
Loaded GDAL runtime: GDAL 2.3.2, released 2018/09/21
Path to GDAL shared files: /usr/share/gdal
GDAL binary built with GEOS: TRUE
Loaded PROJ.4 runtime: Rel. 5.2.0, September 15th, 2018, [PJ_VERSION:
520]
Path to PROJ.4 shared files: (autodetected)
Linking to sp version: 1.3-2
File "/home/mneteler/software/grass78_git/dist.x86_64-pc-linux-
gnu/scripts/v.krige", line 460, in <module>
main()
gnu/scripts/v.krige", line 341, in main
import vkrige_wxgui as GUI
gnu/etc/v.krige/vkrige_wxgui.py", line 25, in <module>
from core.utils import _
(/home/mneteler/software/grass78_git/dist.x86_64-pc-linux-
gnu/gui/wxpython/core/utils.py)
Resolution: | Keywords: v.krige
Comment (by mmetz):
Replying to [ticket:4014 neteler]:
> https://github.com/OSGeo/grass-
addons/blob/master/grass7/vector/v.krige/vkrige_wxgui.py#L25
> with
> Any idea how to fix that? Thanks
Comment (by neteler):
Thanks, that helps.
Still, there is a new error:
g.extension v.krige
v.krige
File "/home/mneteler/.grass7/addons/scripts/v.krige", line 461, in
<module>
main()
File "/home/mneteler/.grass7/addons/scripts/v.krige", line 349, in main
controller=controller)
File "/home/mneteler/.grass7/addons/etc/v.krige/vkrige_wxgui.py", line
415, in __init__
self.Panel = KrigingPanel(self, Rinstance, controller)
127, in __init__
273, in CreatePage
controller=controller)))
632, in __init__
self.LeftSizer.Insert(2, item=VariogramSubSizer)
TypeError: Sizer.Insert(): arguments did not match any overloaded call:
overload 1: 'item' is not a valid keyword argument
overload 2: 'item' is not a valid keyword argument
overload 3: 'item' is not a valid keyword argument
overload 4: 'item' is not a valid keyword argument
overload 5: 'item' is not a valid keyword argument
overload 6: 'item' is not a valid keyword argument
overload 7: argument 'item' has unexpected type 'BoxSizer'
overload 8: 'item' is not a valid keyword argument
overload 9: 'item' is not a valid keyword argument
