GDAL
February 9, 2008, 8:30am
1
#41: g.mapsets crash
Reporter: neteler | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.3.0
Component: default | Version: svn-trunk
Keywords: |
When launching g.mapsets in a new mapset which was generated on command
line
(this is needed to do parallel computations on a cluster):
grass63 ~/grassdata/pat/aqua_lst1km20020706.LST_Night_1km.filt
it crashes:
GRASS 6.3.svn (pat):~ > g.mapsets add=modisLSTaqua,modisLSTterra
Segmentation fault
GRASS 6.3.svn (pat):~ > gdb `which g.mapsets`
GNU gdb 6.6-1mdv2007.1 (Mandriva Linux release 2007.1)
Copyright (C) 2006 Free Software Foundation, Inc.
This GDB was configured as "x86_64-mandriva-linux-gnu"...
Using host libthread_db library "/lib64/libthread_db.so.1".
(gdb) r add=modisLSTaqua,modisLSTterra
Starting program: /home/neteler/grass63/dist.x86_64-unknown-linux-
gnu/bin/g.mapsets add=modisLSTaqua,modisLSTterra
Program received signal SIGSEGV, Segmentation fault.
0x00002ba0dad1904c in G__mapset_name (n=0) at mapset_nme.c:46
46 return mapset_name[n];
(gdb) bt full
#0 0x00002ba0dad1904c in G__mapset_name (n=0) at mapset_nme.c:46
No locals.
#1 0x0000000000401353 in main (argc=2, argv=0x7fffcffdd058) at
main_cmd.c:119
oldname = 0x0
n = 0
i = 0
skip = 0
cur_mapset = 0x0
ptr = (char **) 0x0
tokens = (char **) 0x0
no_tokens = 11168
fp = (FILE *) 0x401a50
module = (struct GModule *) 0x2ba0daf51680
opt1 = (struct Option *) 0x2ba0daf515e0
opt2 = (struct Option *) 0x6074a0
print = (struct Flag *) 0x607560
list = (struct Flag *) 0x2ba0daf515a0
(gdb)
The mapset contains at this stage:
ls -l ~/grassdata/pat/aqua_lst1km20020706.LST_Night_1km.filt/
total 4
drwxr-xr-x 2 neteler neteler 1024 Feb 9 09:08 dbf/
drwx------ 2 neteler neteler 1024 Feb 9 09:09 tmp/
-rw-r--r-- 1 neteler neteler 66 Feb 9 09:08 VAR
-rw----r-- 1 neteler neteler 293 Feb 9 09:08 WIND
Also crashes
g.mapsets -p
Segmentation fault
for possibly the same (to me unknown) reason.
My tries to debug that with 'ddd' failed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/41> ;
GRASS GIS <http://grass.osgeo.org >
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
GDAL
February 9, 2008, 8:45am
2
Resolution: | Keywords:
Comment (by neteler):
Update: apparently the mapset name LENGTH matters:
grass63 ~/grassdata/pat/abcdefghijklmnopqrstuvwxyz123456
GRASS 6.3.svn (pat):~ > g.mapsets -p
abcdefghijklmnopqrstuvwxyz123456 PERMANENT
exit
grass63 ~/grassdata/pat/abcdefghijklmnopqrstuvwxyz1234567
Segmentation fault
echo -n abcdefghijklmnopqrstuvwxyz1234567 | wc -c
33
Ticket URL: <http://trac.osgeo.org/grass/ticket/41#comment:1> ;
GDAL
February 9, 2008, 9:03am
3
The new g.mapsets changesets [30031] (longer buffers) and [30030] (use
GMAPSET_MAX, GPATH_MAX) did not help.
Ticket URL: <http://trac.osgeo.org/grass/ticket/41#comment:2> ;
Hi Markus,
Line 33 in lib/gis/mapset.c:
static char mapset[30];
looks like it may be the problem here. I don't have SVN access right now or else I'd change it myself..
Paul
GDAL
February 9, 2008, 10:43am
5
As suggested by Paul, fixed as [30032]
(http://trac.osgeo.org/grass/changeset/30032 ).
I am not sure yet about the exit status of the function.
Ticket URL: <http://trac.osgeo.org/grass/ticket/41#comment:3> ;
GDAL
April 24, 2008, 1:08pm
6
Priority: major | Milestone: 6.4.0
Changes (by neteler):
* milestone: 6.3.0 => 6.4.0
Ticket URL: <http://trac.osgeo.org/grass/ticket/41#comment:4> ;
GDAL
April 27, 2008, 7:56pm
7
Type: defect | Status: closed
Resolution: fixed | Keywords:
* status: new => closed
* resolution: => fixed
Comment:
Now it works. Closed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/41#comment:5> ;
Commonly referred to as GRASS, this is a Geographic Information System (GIS) used for geospatial data management and analysis, image processing, graphics/maps production, spatial modeling, and visualization. GRASS is currently used in academic and commercial settings around the world, as well as by many governmental agencies and environmental consulting companies. GRASS is official project of the Open Source Geospatial Foundation.
