[GRASS-dev] [GRASS GIS] #411: Makefile uses LD instead of GCC for linking leads to undefined symbol: __stack_chk_fail_local
Reporter: RRosario | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: undefined symbol __stack_chk_fail_local | Platform: Unspecified
      Cpu: x86-32 |
The Makefile for Python SWIG uses LD for linking rather than GCC. On some
Linux systems, this causes Python to throw the error:
$ python -c "import _python_grass6"
   File "<string>", line 1, in <module>
ImportError: ./_python_grass6.so: undefined symbol: __stack_chk_fail_local
when the library python_grass6 is imported due to a stack smash guard.
I have confirmed that replacing LD with CC fixes this problem. On some
distributions of Linux, this can be fixed by adding "-fno-stack-protector"
to CFLAGS.
R.
Ticket URL: <http://trac.osgeo.org/grass/ticket/411&gt;
Component: SWIG (all bindings) | Version: svn-develbranch6
Resolution: | Keywords: undefined symbol __stack_chk_fail_local
  Platform: Linux | Cpu: x86-32
Changes (by RRosario):
  * platform: Unspecified => Linux
  * version: unspecified => svn-develbranch6
  * component: default => SWIG (all bindings)
Ticket URL: <http://trac.osgeo.org/grass/ticket/411#comment:1&gt;
Comment (by kyngchaos):
This isn't right on OSX either. We've spent some effort to get the
wxpython nviz and vdigit to compile correctly on different platforms, so
maybe that method should be used here also (patch attached).
There is still cleanup needed to completely conform to the GRASS make
system, but it should compile correctly now.
Ticket URL: <http://trac.osgeo.org/grass/ticket/411#comment:2&gt;
Comment (by neteler):
What is the status of this report?
Ticket URL: <http://trac.osgeo.org/grass/ticket/411#comment:3&gt;
Comment (by glynn):
Replying to [comment:3 neteler]:
swig/python/Makefile has changed beyond recognition since this was
originally filed. Linking now uses `$(CXX)`.
Ticket URL: <http://trac.osgeo.org/grass/ticket/411#comment:4&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: undefined symbol __stack_chk_fail_local
Changes (by hamish):
  * status: new => closed
  * resolution: => fixed
Comment:
apparently it is non-trivial to add a new "obsolete" resolved status, so
just calling this fixed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/411#comment:5&gt;
