GDAL
December 25, 2008, 3:19pm
1
#412: add bbox check to d.rast
Reporter: karme | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
patch applied
Ticket URL: <https://trac.osgeo.org/grass/ticket/412> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
December 25, 2008, 3:43pm
2
Priority: trivial | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Resolution: | Keywords:
Platform: All | Cpu: Unspecified
Changes (by karme):
* priority: major => trivial
* platform: Unspecified => All
* version: unspecified => svn-develbranch6
* type: defect => enhancement
Comment:
the description should read "patch attached"
Ticket URL: <https://trac.osgeo.org/grass/ticket/412#comment:1> ;
GDAL
December 25, 2008, 7:40pm
3
Comment (by glynn):
Replying to [ticket:412 karme]:
There appear to be a couple of things wrong here:
1. It assumes -o (or the lack of -n in 7.0). Without -o or with -n, a
raster which doesn't overlap the current region should result in a solid
rectangle in the map's null value colour.
2. D_cell_draw_setup() is called unconditionally, but D_cell_draw_end() is
only called if the raster is visible. These calls must be matched, i.e.
either both must be called, or neither.
Apart from that, I would suggest making the patch against 7.0.
Ticket URL: <https://trac.osgeo.org/grass/ticket/412#comment:2> ;
GDAL
December 25, 2008, 11:36pm
4
Comment (by karme):
Attached updated patch addressing both issues.
Ticket URL: <https://trac.osgeo.org/grass/ticket/412#comment:3> ;
GDAL
August 21, 2012, 7:52pm
5
Reporter: karme | Owner: grass-dev@…
Priority: trivial | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: | Platform: All
Cpu: Unspecified |
Changes (by neteler):
* version: svn-develbranch6 => svn-trunk
* milestone: 6.4.0 => 7.0.0
Ticket URL: <http://trac.osgeo.org/grass/ticket/412#comment:4> ;
GDAL
April 20, 2014, 6:47pm
6
Component: Display | Version: svn-trunk
Keywords: d.rast | Platform: All
Cpu: Unspecified |
* keywords: => d.rast
* component: Default => Display
Ticket URL: <http://trac.osgeo.org/grass/ticket/412#comment:5> ;
