#413: doxygen comments in get_row.c are wrong?
Reporter: karme | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Either the code in get_row.c is wrong or the the doxygen strings.
G_get_raster_row does not return 0 if the row is outside the window.
Attached a patch trying to fix this. Note: this was a quick hack I tested
while trying to speed up d.rast => only supplied to explain the problem.
Reporter: karme | Owner: grass-dev@…
Priority: major | Milestone: 6.4.3
Component: Default | Version: svn-releasebranch64
Cpu: Unspecified |
Comment(by glynn):
Replying to [ticket:413 karme]:
The doxygen strings are wrong.
There's no reason for higher-level code to care about what is essentially
an implementation detail. It shouldn't matter whether the row is all-nulls
because it's outside the array or because the stored data happens to be
all-nulls.
Priority: major | Milestone: 6.4.4
Component: LibGIS | Version: svn-releasebranch64
Keywords: G_get_raster_row(), doxygen | Platform: All
Cpu: All |
Comment(by mlennert):
Replying to [comment:2 glynn]:
essentially an implementation detail. It shouldn't matter whether the row
is all-nulls because it's outside the array or because the stored data
happens to be all-nulls.
IIUC, return values are either 1 or -1, so just erasing the line in the
comments mentioning "return 0" should be enough ?
Cpu: All |
Comment(by glynn):
Replying to [comment:4 mlennert]:
Right.
The internal functions compute_window_row() and get_map_row_nomask()
return 0 if the row is outside of the map's data, but that detail doesn't
propagate up to any of the documented public functions.
Type: defect | Status: closed
Resolution: fixed | Keywords: G_get_raster_row(), doxygen
Platform: All | Cpu: All
Changes (by mlennert):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:5 glynn]:
the comments mentioning "return 0" should be enough ?
> Right.
Correction of doxygen comment committed to devel6 (r60143) and rel64
(r60144).
