[GRASS-dev] [GRASS GIS] #414: bogus rectangles on map display
Reporter: msieczka | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-develbranch6
Keywords: | Platform: All
      Cpu: All |
1. start vdigit
2. quit it
3. press left mouse button over map display and drag - a yellow dashed
rectangle is being drawn
Weird. Seems bogus. What tool is it?
Now select "Query vector map - edit mode" tool. Again try dragging the
cursor over the map display with left mouse button pressed - this time a
reddish dashed rectangle is being drawn. What is the purpose of that
rectangle?
Ticket URL: <http://trac.osgeo.org/grass/ticket/414&gt;
Component: wxGUI | Version: svn-develbranch6
Resolution: | Keywords:
  Platform: All | Cpu: All
Changes (by msieczka):
  * component: default => wxGUI
Ticket URL: <http://trac.osgeo.org/grass/ticket/414#comment:1&gt;
  Reporter: msieczka | Owner: martinl
      Type: defect | Status: assigned
Changes (by martinl):
  * status: new => assigned
  * owner: grass-dev@lists.osgeo.org => martinl
* cc: grass-dev@lists.osgeo.org (added)
Comment:
Hopefully fixed in r35060 (devbr6), r35061 (trunk) and r35062 (relbr64).
Ticket URL: <http://trac.osgeo.org/grass/ticket/414#comment:2&gt;
      Type: defect | Status: closed
Resolution: worksforme | Keywords:
Changes (by cmbarton):
  * status: assigned => closed
  * resolution: => worksforme
Comment:
I don't see any rectangles if I start and then close vdigit (on Mac OSX).
On the other hand, vdigit is still pretty buggy for me in other respects.
Hopefully this particular issue can be close. Please retest on other
platforms.
Ticket URL: <http://trac.osgeo.org/grass/ticket/414#comment:3&gt;
      Type: defect | Status: reopened
  * status: closed => reopened
  * resolution: worksforme =>
Comment:
There was a fix by Martin Landa 3 days ago actually.
Ticket URL: <http://trac.osgeo.org/grass/ticket/414#comment:4&gt;
Resolution: fixed | Keywords:
  * status: reopened => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/414#comment:5&gt;
