#415: querying vector map crashes wxGUI
Reporter: msieczka | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: critical | Milestone: 6.4.0
Component: wxGUI | Version: svn-develbranch6
Keywords: | Platform: Linux
Cpu: x86-64 |
In "edit mode":
File "/usr/lib/python2.5/site-
packages/wx-2.8-gtk2-unicode/wx/_core.py", line 14572, in
<lambda>
lambda event: event.callable(*event.args, **event.kw) )
packages/wx-2.8-gtk2-unicode/wx/lib/scrolledpanel.py", line
74, in _SetupAfter
self.SetVirtualSize(self.GetBestVirtualSize())
packages/wx-2.8-gtk2-unicode/wx/_core.py", line 14522, in
__getattr__
raise PyDeadObjectError(self.attrStr % self._name)
wx._core
PyDeadObjectError
The C++ part of the ScrolledPanel object has been deleted,
attribute access no longer allowed.
<lambda>
74, in _SetupAfter
__getattr__
wx._core
PyDeadObjectError
In "display mode":
(Fri Dec 26 19:58:08 2008)
v.what --q -a map=mapa@PERMANENT east_north=594970.677739,5678071.967777
distance=42.521482
East: 594970.677739
North: 5678071.967777
Map: mapa
Mapset: PERMANENT
Type: Line
Length: 6804.484567
Layer: 1
Category: 1
Driver: dbf
Database: /home/grassdata/caves_utm33/PERMANENT/dbf/
Table: mapa
Key column: cat
cat : 1
cusik : aha
uha : 986467345
Exception in thread Thread-1:
File "/usr/lib/python2.5/threading.py", line 486, in
__bootstrap_inner
self.run()
File "/usr/local/grass-6.4.svn/etc/wxpython/gui_modules/go
utput.py", line 95, in run
returncode=self.requestCmd.module.returncode,
AttributeError: 'NoneType' object has no attribute 'module'
Ticket URL: <http://trac.osgeo.org/grass/ticket/415>
