[GRASS-dev] [GRASS GIS] #419: cairo compilation error
Reporter: neteler | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: default | Version: svn-trunk
Keywords: | Platform: Linux
      Cpu: x86-32 |
Trying to compile GRASS trunk on grass.osgeo.org (FC4 with cairo 1.4.4), I
get
make[1]: Leaving directory
`/home/neteler/grass7_svn_head_bin_snapshot/trunk/lib/cairodriver'
gcc -I/home/neteler/grass7_svn_head_bin_snapshot/trunk/dist.i686-pc-linux-
gnu/include -I/home/neteler/binaries/include -g -Wall
-Werror-implicit-function-declaration -fno-common
-I/home/neteler/binaries/include -fPIC -I../driver -I/usr/include/cairo
-DUSE_X11=1 -DPACKAGE=\""grasslibs"\"
gnu/include -o OBJ.i686-pc-linux-gnu/Draw_bitmap.o -c Draw_bitmap.c
Draw_bitmap.c: In function 'Cairo_Bitmap':
Draw_bitmap.c:36: error: implicit declaration of function
'cairo_format_stride_for_width'
What's the minimum version of cairo needed here?
Please update REQUIREMENTS.html:
grep -i cairo REQUIREMENTS.html
<li><B>Cairo</B> (Cairo graphics library, Version &gt;= XX)<BR>
Ticket URL: <http://trac.osgeo.org/grass/ticket/419&gt;
Resolution: | Keywords:
  Platform: Linux | Cpu: x86-32
Comment (by glynn):
Replying to [ticket:419 neteler]:
I get
That function needs 1.6.
I'd rather work around the requirement.
Ticket URL: <http://trac.osgeo.org/grass/ticket/419#comment:1&gt;
Comment (by neteler):
Replying to [comment:1 glynn]:
That would be appreciated since I don't get Cairo 1.6 compiled on the
oldish FC4 (and no way to update that).
Ticket URL: <http://trac.osgeo.org/grass/ticket/419#comment:2&gt;
Comment (by mlennert):
1.4.4), I get
Looks like 1.5.8 would be enough:
http://cairographics.org/news/cairo-1.5.8/
I have the same problem with
cairo_xlib_surface_get_xrender_format
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/419#comment:3&gt;
Comment (by glynn):
Replying to [comment:3 mlennert]:
I'll update the test accordingly.
That should be conditionalised upon CAIRO_HAS_XLIB_XRENDER_SURFACE. The
function should be defined in cairo-xlib-xrender.h.
Can you provide more details?
Ticket URL: <http://trac.osgeo.org/grass/ticket/419#comment:4&gt;
Replying to [comment:4 glynn]:
svn update and recompile now gives only one error:
mlennert@geog-pc40:~/SRC/GRASS/grass_trunk/general/g.cairocomp$ export
LANG=C; make
gcc -L/home/mlennert/SRC/GRASS/grass_trunk/dist.i486-pc-linux-gnu/lib -Wl,
--export-dynamic -Wl,-rpath-
link,/home/mlennert/SRC/GRASS/grass_trunk/dist.i486-pc-linux-gnu/lib -o
gnu/bin/g.cairocomp OBJ.i486-pc-linux-gnu/main.o -lgrass_gis
-lgrass_datetime -lz -lXrender -lcairo -lX11 -lm -lz
OBJ.i486-pc-linux-gnu/main.o: In function `init_xlib':
/home/mlennert/SRC/GRASS/grass_trunk/general/g.cairocomp/main.c:118:
undefined reference to `cairo_xlib_surface_get_xrender_format'
collect2: ld returned 1 exit status
make: *** [/home/mlennert/SRC/GRASS/grass_trunk/dist.i486-pc-linux-
gnu/bin/g.cairocomp] Error 1
Using cairo 1.4.14 on Debian stable.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/419#comment:5&gt;
Comment (by glynn):
Replying to [comment:5 mlennert]:
Right; I can only fix this in the sense of adding a configure check for
cairo_xlib_surface_get_xrender_format() and not building g.cairocomp if
it's missing. g.cairocomp can't work without that function, but the cairo
driver can.
Ticket URL: <http://trac.osgeo.org/grass/ticket/419#comment:6&gt;
Replying to [comment:6 glynn]:
driver can.
And do I understand correctly that g.cairocomp is need to use the GUI, at
least when using the default cairo driver ?
I guess it's time to compile a more recent version of cairo, then...
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/419#comment:7&gt;
Comment (by glynn):
Replying to [comment:7 mlennert]:
at least when using the default cairo driver ?
No. At present, g.cairocomp isn't used.
Using the cairo driver to generate X pixmaps which can be composited by
g.cairocomp offers a faster alternative to using PNM files, but it
requires X, the XRender extension, and a recent version of cairo built
with X and XRender support. Even if/when the GUI does use g.cairocomp, the
use of PNM files will still need to be retained as a fallback.
Ticket URL: <http://trac.osgeo.org/grass/ticket/419#comment:8&gt;
  Reporter: neteler | Owner: martinl
      Type: defect | Status: assigned
Changes (by martinl):
  * status: new => assigned
  * owner: grass-dev@lists.osgeo.org => martinl
* cc: grass-dev@lists.osgeo.org (added)
Comment:
Done in r36922.
Ticket URL: <https://trac.osgeo.org/grass/ticket/419#comment:9&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by neteler):
  * status: assigned => closed
  * resolution: => fixed
Comment:
Great, finally it causes no more errors on FC4 with cairo 1.4.4. Hence I
can activate a GRASS 7 Linux binaries weekly cronjob.
Ticket URL: <https://trac.osgeo.org/grass/ticket/419#comment:10&gt;
