#423: "please wait loading attribute data..." and no way to see data..
Reporter: marchesinivan | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.5.0
Component: wxGUI | Version: svn-develbranch6
Keywords: attribute data | Platform: Linux
Cpu: x86-32 |
When I try to have a look to attribute data (by means of "show attribute
data" option in the right click menu of the vect map listed in the grass
gis layer manager) a gray windows appears saying "please wait loading
attribute data" but nothing happen and the windows doesn't disappear. I
have found this problem using geology map of spearfish dataset.
I'm working on a debian testing.
Resolution: | Keywords: attribute data
Platform: Linux | Cpu: x86-32
Comment (by martinl):
I cannot reproduce this behaviour. wxGUI code is currently under heavy
development in develbranch_6 and trunk - some problems can occur. Try the
last revision.
Type: defect | Status: closed
Resolution: fixed | Keywords: attribute data
Changes (by marchesinivan):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:1 martinl]:
last revision.
Thanks Martin..
You are right...
whith the last revision the problem is solved!!!
many thanks
